bouncing idle
Old Mar 28, 2006 | 07:16 PM
6doorsentra's Avatar
Default bouncing idle
when i start my car up the idle is up at around 3k...then eventually it goes down to like 2 and ahalf....it'll bounce up to 3 then back down to 1...then back to 2 then back to 1 then back to 2 and so forth...it just keeps bouncing. When the vehicle is warmed up, it'll settle down but its around 1800... i'm used to my vehicle being around 1k or less for idle...not all high and crazy... any ideas?
all help is appreciated.
Old Mar 28, 2006 | 07:35 PM
im thinking the fast idle control valve on the back of the intake manifold. Something about takeing it apart and making sure everything is fit and nice and clean...sometimes, the white plastic piece inside is loose. Sound about right?
Old Mar 28, 2006 | 08:44 PM
LsHoney84's Avatar
Default Re: (6doorsentra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6doorsentra &raquo;</TD></TR><TR><TD CLASS="quote">im thinking the fast idle control valve on the back of the intake manifold. Something about takeing it apart and making sure everything is fit and nice and clean...sometimes, the white plastic piece inside is loose. Sound about right? </TD></TR></TABLE>
I think you mean idle air control valve on the back of the intake manifold. This only operates when the engine has reached normal operating temperature.
Now if the idle is bouncing when the engine is cold, its the fast idle thermo valve. Theres a DIY on here. Search.
If nothing else works, it could be a vacuum leak or air in your cooling system.
Old Mar 28, 2006 | 08:46 PM
Tornadom's Avatar
Default Re: bouncing idle (6doorsentra)
Sounds like a vacuum leak to me.
Old Mar 28, 2006 | 11:22 PM
manyakiexpi's Avatar
Default Re: bouncing idle (Tornadom)
its definately the fast idle thermo valve. i had this problem with the integ i just bought. found the DIY for it and was able to fix it easily.
https://honda-tech.com/zerothread?id=1564019
there u go. good luck on the fix. its really easy so hopefully u dont get all stressed out about it.
Zee.I
Jul 11, 2021 11:36 PM
NAmodified
Feb 1, 2007 11:46 AM
dnbruut
Jan 12, 2007 02:38 AM
JDMkidGSR
Nov 9, 2006 05:26 PM
