Idle problem...getting tired of it.
Old Aug 18, 2006 | 12:00 PM
JDMkidGSR's Avatar
Default Idle problem...getting tired of it.
Ok well its been like a few months since Ive had this. When I had my stock gsr manifold everything worked great. After the Skunk2 manifold install my car idles up and down from 1000-2500rpms. Ive been reading up on this and Ive changed out all the Valves. Got a new emission canister cuz mine was broken, all the hoses are connected tightly. When I have the A/C it stays at idle good for a while then jumps up and down, and when A/C is off the idle moves up and down all the time. I dont know what other thing to check.
Old Aug 18, 2006 | 04:00 PM
BSERIESPOWER's Avatar
did you check your idle air control valve? thats the one on the back of the intake manifold.
Old Aug 18, 2006 | 04:04 PM
B18c5__Owns's Avatar
From: I Bet You Really Want To Know Where In, NJ, USA
Default Re: (BSERIESPOWER)
anybody else have any input, my friends car has the same problem im trying to solve..
I was thinking vacuume lines but imnot sure
Old Aug 19, 2006 | 09:50 AM
JDMkidGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSERIESPOWER &raquo;</TD></TR><TR><TD CLASS="quote">did you check your idle air control valve? thats the one on the back of the intake manifold.</TD></TR></TABLE>
yea dude, I replaced that one already. I have no other clue to help me determine the problem of my car.
Old Aug 19, 2006 | 10:02 AM
kpop's Avatar
Default Re: (JDMkidGSR)
air leak and adjust ur tottle cable
Old Aug 19, 2006 | 10:06 AM
VTECth1s's Avatar
Do you have any CEL codes? FITV, throttle position..possibly
Old Aug 20, 2006 | 06:57 AM
Default Re: (egg6vtak)
so did u solve it??
Old Aug 20, 2006 | 08:18 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Idle problem...getting tired of it. (JDMkidGSR)
Any wires unplugged? My ls would do that when one wasn't plugged in, or if the FPR hose came off.
Old Aug 20, 2006 | 08:55 AM
JDMkidGSR's Avatar
Default Re: Idle problem...getting tired of it. (CleanLikeJdm)
Well I did replace the Throttle cable with an ITR one, I didnt adjust it. What Im I suppose to do to adjust it though, So I can do it right after work.
Note: IT does it when AC is Off, and stops when AC is on and then continues.
Old Aug 20, 2006 | 09:01 AM
JDMkidGSR's Avatar
I aslo replaced the top sensor, from the throttle body from an lsvtec motor I have laying around, its good. I think CELS of the throttle position and the vtec solenoid came out but this is recent the idle problem ive had it for months without thee check engine light on.
Old Aug 20, 2006 | 09:03 AM
SE3Pimp's Avatar
its a vacuum leak. my friend had the same problem. recheck all your work you didnt put a vacuum line back on for sure
Old Aug 20, 2006 | 09:07 AM
JDMkidGSR's Avatar
Default Re: Idle problem...getting tired of it. (EndlessDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EndlessDc2 &raquo;</TD></TR><TR><TD CLASS="quote">its a vacuum leak. my friend had the same problem. recheck all your work you didnt put a vacuum line back on for sure</TD></TR></TABLE>
Hopefully its that, I'll take a picture of the vacuum lines and of the coolant lines to see if you guys can help me out. I want to have it ready by tomorrow I dont like having my car sounding like Sh*t, lol
Old Aug 20, 2006 | 10:30 AM
rdssk8rcs1's Avatar
did you change the throttle body when you changed the manifold by any chance? there is a whole in the stock throttle bottle allowing vacum to enter the matching hole in the manifold, most after market manifolds dont have this whole.... what you are going to have to do is take out the "plunger like" valve underneath the throttle body that allows coolant to cool down the throttle body, then seal up the holes underneath the throttle body, dont forget to connect the coolant hoses that used to go to that valve and connect it to the hose going into the intake manifold......good luck
Old Aug 20, 2006 | 01:52 PM
JDMkidGSR's Avatar
Default Re: Idle problem...getting tired of it. (rdssk8rcs1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 &raquo;</TD></TR><TR><TD CLASS="quote">did you change the throttle body when you changed the manifold by any chance? there is a whole in the stock throttle bottle allowing vacum to enter the matching hole in the manifold, most after market manifolds dont have this whole.... what you are going to have to do is take out the "plunger like" valve underneath the throttle body that allows coolant to cool down the throttle body, then seal up the holes underneath the throttle body, dont forget to connect the coolant hoses that used to go to that valve and connect it to the hose going into the intake manifold......good luck</TD></TR></TABLE>
Ok So I plug the two tubes on the bottom of the throttle body, and connect the lines together RIGHT??
Its the lil valve that carries the springs inside to adjust the idle right, I plug the inlets to that and then re-route the hoses instead of going into the valve, is that what you mean. If yes then Imma get this fixed today.
P.S. Yes I do have the stock Throttle Body.
Old Aug 20, 2006 | 02:31 PM
John 07's Avatar
Hey, my old LS was doing that too. i took it to the dealer and they figured the problem. I had a crack in the block.
Old Aug 20, 2006 | 06:35 PM
SE3Pimp's Avatar
thats the man i wanted to hear from lol nice write up jimmy
Old Aug 20, 2006 | 09:54 PM
rdssk8rcs1's Avatar
haha yeah well i thought i needed to share that because it took me about a month to finally get around to finding the problem and fixing it....save you some time
Old Aug 21, 2006 | 06:14 PM
JDMkidGSR's Avatar
I tried that dude, but i Dont know if I have to plug up the holes real good I just did it the cheap way I pu on some screws to plug them. LOL But its still doing it.
Old Aug 22, 2006 | 01:07 PM
IC x Prince's Avatar
New User
hey, i have th re answer which i guess you guys are all new to the honda world because this is an old problem that used to get discussed here on the dail a few years back. but anyway...
it's your throttle postioning sensor. no need to replace anything. it's an easy fix. just take the throttle body off, then replace the two rivet looking screws on the TPS with ones you can use, i always use torx bits. then start the car, adjust it til the surging stops.
Old Aug 22, 2006 | 03:39 PM
rdssk8rcs1's Avatar
Default Re: Idle problem...getting tired of it. (IC x Prince)
it could be one of many problems, i would think that he would have tried adjusted that sensor but more often than not its a vacume leak somewhere around the engine, and if it was a vacume leak it would have to be air tight so some screws in the holes in the throttle body probably wouldnt fix it
Old Aug 22, 2006 | 04:33 PM
neodre's Avatar
You want help well u got it.
jus check out this tread it might solve ur problem
https://honda-tech.com/zerothread?id=1564019
Old Nov 5, 2006 | 03:05 PM
JDMkidGSR's Avatar
Default Re: Idle problem...getting tired of it. (neodre)
I finally fixed the problem...
It was the TPS. You dont have to "Drill" it out. Simply get a hand saw and cut across the rivets to make it seem like if it were a screw, after you completely cut down to where you reach the end then get a flat head and unscrew it that way you can use it again.
Now to adjust the TPS, if you have a VAFC, set it in the Throttle volts. (You dont need to turn the car on) Just have the key turned all the way untill the acc. lights are on. Then adjust the TPS. The closer you move the TPS to the pass. side the voltage will go up to a max of .6 and if you move it to the driver side itll be .4. In this case I set mine at exactly .60. It idled completely fine, but the idle was at 2k rpms. So after letting the car warm up the idle never went down so I took off the throttle body, and adjusted the screw to close the throttle a bit and lower the idle. Then after that, My car idles completely fine and idles at 900rpms. HOPE this works for you guys.
Old Nov 5, 2006 | 04:46 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
ya but now your dumpin more fuel than u should be, the sensor is supposed to be at .5 when the throttle is closed
Old Nov 7, 2006 | 08:23 AM
JDMkidGSR's Avatar
Default Re: Idle problem...getting tired of it. (H22EHSI)
YEa sorry if I didnt mention this when u adjust the lil screw on the throttle bracket it lowers the voltage and evens it out. so its more like .465
Old Nov 7, 2006 | 09:26 AM
BlackHonda's Avatar
i had the same problem just replace your throttle body position sencer
