Ring Gap Size?
Old Jul 10, 2004 | 02:26 PM
MilanoFury's Avatar
Default Ring Gap Size?
what should my ring gap be if I plan on running 25-30lbs of boost and making 500 to 600 hp?
Old Jul 10, 2004 | 03:18 PM
MachAF's Avatar
Default Re: Ring Gap Size? (Crazy18)
what pistons are you using?
if using CP I'd go with:
0.019 or 0.018
i believe boosted hybrid is using 0.019" on the 500whp motor.
Old Jul 10, 2004 | 03:26 PM
Muckman's Avatar
Moderator in Chief
I went with .019" top, .021" bottom. But you might want to go a little bigger if your seriously shooting for 600hp.
https://honda-tech.com/zerothread?id=918153
Old Jul 10, 2004 | 05:50 PM
b18prl's Avatar
Default Re: Ring Gap Size? (Muckman)
what bore size you guys talking about because i went with .016" and .014" bottom on cp 81.50 mm.
Old Jul 10, 2004 | 05:55 PM
MilanoFury's Avatar
Default Re: Ring Gap Size? (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">what pistons are you using?
0.019 or 0.018
i believe boosted hybrid is using 0.019" on the 500whp motor.</TD></TR></TABLE>
They are CP 84mm 9:1 pistons. So probably like 0.019 - 0.021.
Old Jul 10, 2004 | 09:50 PM
Muckman's Avatar
Moderator in Chief
84mm bore CP pistons here.
Old Jul 10, 2004 | 11:00 PM
MilanoFury's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">84mm bore CP pistons here.</TD></TR></TABLE>
How much boost are you running and what kind of power?
rich7777
10
Feb 25, 2010 11:58 AM
marvinmark21
Jan 14, 2008 09:36 AM
ghettocrxsi
Oct 29, 2005 03:58 PM
lemongreenhatch
Sep 29, 2004 09:13 AM
JunIntegra
63
Feb 15, 2004 11:00 PM
