boosting it up?
Old Oct 16, 2006 | 07:38 PM
Slowass2dr's Avatar
Default boosting it up?
alright i have a 1994 integra ls with a turbo kit. its a greddy turbo kit with a big intercooler and the turbo is preety big but not sure what kind since i bough the car with it anyways right now am boosting 6 pounds and thats with the manual boost controler all the way open so thats my lowest boost setting. all i have is a fpr, RC injectors and the car is running with a P28, i dont have any fuel managemet program. the ls motor is from a 2000 ls and is stock, i want to bring my boost up to 8-10 pounds, how would i go about that, do i just adjust the boost with the manual boost controller or do i need a program so i can get more fuel. am kinda confused so all the help i get will be apriciated
Old Oct 16, 2006 | 08:04 PM
95dc2teg's Avatar
Default Re: boosting it up? (Slowass2dr)
Just to be safe you should probably get rid of the fmu and just get a decent type of engine management ie. crome, hondata, uberdata. Then after that you can turn up the boost!
oh and by the way how many cc's are ur RC injectors?
Old Oct 16, 2006 | 08:05 PM
CleanLikeJdm's Avatar
Hype-R Stalker
If you're not going to go with any kind of fuel management,
Just adjust your FPR up a little more, and then adjust your boost.
Of course it wouldn't be the right way to do things,
you're get worse gas mileage, along with a funny idle/partial throttle,
But it would work fine for a temporary thing.
Old Oct 16, 2006 | 08:11 PM
Hype-R Stalker
Default Re: boosting it up? (95dc2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">Just to be safe you should probably get rid of the fmu</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slowass2dr &raquo;</TD></TR><TR><TD CLASS="quote"> all i have is a fpr, RC injectors and the car is running with a P28 </TD></TR></TABLE>
What fmu?
Old Oct 16, 2006 | 08:22 PM
Slowass2dr's Avatar
Default Re: boosting it up? (CleanLikeJdm)
yeah i dont have a fmu all i have is a fpr, i just want to bring it up temporarely cus am goin to atco this weekend to see what times i do, i heard that the factory ls can hold the 10 pounds right?
Old Oct 16, 2006 | 08:28 PM
95dc2teg's Avatar
woops miss took fpr with fmu, my bad
Old Oct 16, 2006 | 09:33 PM
LoseRPunKx182's Avatar
stop drivin the car. what do u mean u have no management system it shouldn't be boosting daily. u should look into ur car more. u want more boost, get it chipped or hondata or whatever, bigger injectors (maybe depending on what u have now) and tuned. dont turn up ur fpr lol
Old Oct 17, 2006 | 07:28 AM
Slowass2dr's Avatar
Default Re: boosting it up? (LoseRPunKx182)
well it must be chipped because the car is runnin on a p28, thats a 92-95 sohc vtec ecu, and i dont think i have to mess with the fpr because wen it gets more boost it should open up more cus of the more pressure correct? anyways thnks
Old Oct 19, 2006 | 08:41 PM
Sack Master's Avatar
1:1 boost referencing regulator is not going to change the ammount of fuel going in dramatically like a say a 12:1 or even 8:1 would. That thing needs to be tuned. Just a 1:1 will not do what you want. Either you're gonna hurt your motor from going deathly lean or that car is washing the rings out under light/no throttle. Whatever the case may be. You need to change something and do it soon.
Old Oct 19, 2006 | 10:31 PM
TurboGS-R's Avatar
Default Re: boosting it up? (Sack Master)
Get Hondata S300B and have it tuned for 8-10 lbs, whichever you prefer. You also may want a fuel pump like Walbro. You will eventually need an aftermarket clutch as you'll soon see.
Old Oct 20, 2006 | 05:02 AM
Slowass2dr's Avatar
Default Re: boosting it up? (TurboGS-R)
yeah am istallin an aftermarket clutch today, and i think i t already has a fuel pump because i have this little problem tha wen my gas is below half its hard to start so i think that they might have installed one. also what do u guys think if i just bost it up a little with the boost controller, i can run it without breakin the motor like i said i just wanna bring it up to like 8-10 pounds
Old Oct 20, 2006 | 07:02 AM
Zion-I's Avatar
no engine management is asking for trouble if you want to turn up the boost.
Old Oct 20, 2006 | 07:08 AM
Fida's Avatar
Default Re: boosting it up? (GrooveDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrooveDC2 &raquo;</TD></TR><TR><TD CLASS="quote">no engine management is asking for trouble if you want to turn up the boost.</TD></TR></TABLE>
I agree
Old Oct 20, 2006 | 07:51 AM
soa p's Avatar
Default Re: boosting it up? (Fida)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fida &raquo;</TD></TR><TR><TD CLASS="quote">
I agree </TD></TR></TABLE>
thread hijack inc
is that your DA in the avatar? more pics
Old Oct 20, 2006 | 10:33 AM
Slowass2dr's Avatar
Default Re: boosting it up? (soap)
well i guess ill leave the boost like that for now, and naw thats not my car in the advitar lol but i have some pics of mine here http://profile.myspace.com/ind...64008
Modified by Slowass2dr at 12:55 PM 10/20/2006
Old Oct 20, 2006 | 12:40 PM
TurboGS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slowass2dr &raquo;</TD></TR><TR><TD CLASS="quote">yeah am istallin an aftermarket clutch today, and i think i t already has a fuel pump because i have this little problem tha wen my gas is below half its hard to start so i think that they might have installed one. also what do u guys think if i just bost it up a little with the boost controller, i can run it without breakin the motor like i said i just wanna bring it up to like 8-10 pounds </TD></TR></TABLE>
I don't think that signifies having a Walbro fuel pump because I have a primary and secondary Walbro and I always have my car on 1/2 a tank or less.
Old Oct 20, 2006 | 01:15 PM
yc_dc4mar's Avatar
i still think you should get it tuned. hondata/chrome
i wouldnt take any chances.
especially if your ganna rip on it everyonce in a while, and i'm sure you will
Old Oct 21, 2006 | 12:27 PM
Slowass2dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboGS-R &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think that signifies having a Walbro fuel pump because I have a primary and secondary Walbro and I always have my car on 1/2 a tank or less. </TD></TR></TABLE>
yea but i was thinkin that maybe they did something wrong during the instaltion, but not sure
Did anyones see the pics
teg_racer
Sep 13, 2010 05:27 AM
SloB16crxMike
Aug 15, 2006 10:31 AM
mybarra
Apr 2, 2004 12:28 AM
Wizard45
Mar 22, 2004 10:37 AM
