block differences
Old Oct 21, 2004 | 07:16 PM
sly_106's Avatar
Default block differences
Whats the difference (or is there any) between the b18c1 block from an obd1, 2a, and 2b car?
Old Oct 21, 2004 | 07:37 PM
RidinStock's Avatar
Default Re: block differences (sly_106)
I think the block is the same, because OBD represents On Board Diagnostics, and controls more of the emissions. Then again, I could be wrong, cuz I know the B18A in a 91 integra has 10 less hp than a 93. Bump for more info!
Old Oct 21, 2004 | 07:59 PM
sly_106's Avatar
Default Re: block differences (RidinStock)
Yeah I wasn't sure if there were extra sensors or anything on the actual block for the obd2s vs. the obd1s, etc.
Old Oct 21, 2004 | 08:09 PM
IN VTEC's Avatar
OBD-2 engines had a CKF sensor mounted on the oil pump, and a revised lower timing belt cover was used.
Lack of oil cooler on OBD-2 engines, which facilitated a change in the main water pipe. I'm not sure what happened to the coolant return nipple in the block tho now that I think about it.
Simplified coolant routing that used a revised thermostat housing that is sans an 8mm nipple.
The actual block casting and internals are unchanged (except for maybe the oil cooler coolant return nipple). It's the stuff surrounding the bare block that changed.
Old Oct 21, 2004 | 08:35 PM
sly_106's Avatar
Default Re: block differences (IN VTEC)
so, for example, a gsr bare block from an obd1 would be the same as a gsr bare block from obd2 then?
Old Oct 21, 2004 | 08:45 PM
IN VTEC's Avatar
Yup, with maybe the exception of the coolant nipple for the oil cooler.
Old Oct 22, 2004 | 01:14 AM
sly_106's Avatar
cool, thank you
Honderachinaldo
Jul 16, 2019 08:28 PM
jthrasher1
Jun 13, 2010 07:22 PM
integraboosted
Oct 13, 2007 09:20 PM
h22_crx
Oct 16, 2005 05:14 PM
THEUSED
Apr 27, 2005 07:37 AM
