bad temp sensor?
Old Nov 23, 2010 | 07:54 PM
kendezzy's Avatar
Default bad temp sensor?
so my temp.keeps goin up..and i already change my thermostat to see if thats the problem..but it still goes up..and the temp. will keep goin up and down...anyone know what the problem can be?
Old Nov 23, 2010 | 07:55 PM
koss1229's Avatar
Default Re: bad temp sensor?
Does your fan turn on?
Old Nov 23, 2010 | 07:58 PM
kendezzy's Avatar
yeah
Old Nov 23, 2010 | 08:24 PM
el crapitan's Avatar
did you properly purge the air? is your rad cap cycling correctly?
Old Nov 23, 2010 | 08:33 PM
kendezzy's Avatar
yup..u think its the coolant temp seensor?or how can i tell if its bad?
Old Nov 23, 2010 | 08:39 PM
measure resistance. both cold and hot
Old Nov 23, 2010 | 08:43 PM
em1guy909's Avatar
i knew my temp sensor was bad when it would show it was getting hot even when the motor wasnt on it was just on the on position..changed it and solved the problem... you should see if yours does that
Old Nov 23, 2010 | 09:15 PM
ye, if it's clearly reading inaccurately, ie hot when cold, it's the sending unit. do not get it confused with the temp sensor, which relays signal to the ecu. the sending unit relays signal to the gauge
97milanoLS
Jan 13, 2011 06:56 PM
coolusername
Aug 10, 2007 03:52 AM
ek4d00r
Aug 1, 2005 04:12 PM
vtecaccord 1
Dec 7, 2004 05:59 AM
SPORT INJECTION
Oct 31, 2004 10:36 PM
