Automatic transmission slipping, is bad or something simple wrong? (solved)
I have a 99 civic d16 with auto transmission. I was driving and then my speed started decelerating but the engine runs fine and revs up like normal when pressing the pedal.
I came to a stop and verified I could not go forward or reverse. It's basically like the equivalent of having the clutch pressed in on a standard. I shut the car off and started it again and then was able to drive about 20 feet before I happened again.
I'm not very familiar with automatics. Do these symptoms match something somewhat easy to fix or am I going to need to look for a torque converter or a whole new tranny ?
Re: Automatic transmission issue
It doesn't matter if it's in 2, d3, d4 or reverse. All will work for up to 30 seconds then all of a sudden it's like having a clutch pedal pushed all the way in and none of them do anything.
Sitting idle for a minute does nothing to help however shutting the car off for minute then starting it again resets the 0-30 seconds of it working.
And after trying this a few times I now have a p0730 code. No others to accompany it.
Seagull Management
Usually you'll get PO730 when the transmission is slipping. The ratio is incorrect due to slippage. Even if that car has the wrong transmission it will work other than throwing codes and shifting weird, but it wont slip like that.
re: Automatic transmission slipping, is bad or something simple wrong? (solved)
Ive owned this car for only about 4 months. From what I could tell everything appeared OEM except for a short air intake. I did not notice any symptoms of transmission issues until yesterday morning.
Is it worth while to try doing a transmission fluid drain and refill ? And otherwise does this sound like I should be looking for a new torque converter or a whole transmission?
Seagull Management
Nope.
Both. Most likely you've got debris floating around everywhere inside the trans and torque converter. What tends to happen if you replace just one part or the other is the debris left in what you didn't replace is still floating around and destroys both parts again. At the very least have the torque converter cut open and checked out by a transmission shop and put back together before reusing it. If you look around you can get these things used dirt cheap. I paid $75 for transmission and torque converter together the last time I needed one. Just make sure you get the right trans. CX/DX/LX are the same, EX is unique to itself.
I never narc'd on nobody!
Thanks for the responses guys. I have an update.
I ended up changing the tranny fluid and having the same problem. Then I dumped the new fluid, filtered some crap out of it, then poured it back in.
Did this about a dozen times before it started going through the filter without leaving a bunch of junk. Took it for a 5 mile drive with no issue and filtered the fluid one more time to make sure there wasn't any new crud in it.
In hindsight. I wonder if the filter was clogging up and causing it to act like an automatic that is low on fluid. Then shutting the car off probably let the junk fall from the filter which is why it would drive fine for about 30 seconds again after I would start the car. Too soon to tell if this is a permanent fix but it's looking optimistic. I should probably install an in-line filter to put between the tranny and radiator to prevent this in the future. That or maybe just regular fluid changes would do it. For all I know previous owners may have never changed it.
I've heard Honda automatics can come back after a couple of fluid changes.
When you drained it did you notice that the drain plug (magnetized) pulled out a long line of filings? If it did it was probably the first time the fluid was changed. After additional changes the filing collection really goes away.
I used Honda fluid that I bought at the dealership.
People denigrate Honda automatics but they take a lot of abuse and neglect and keep on working.
Yeah it looks like gray grease on the end of the drain plug. I had a giant blob of it to wipe after draining the original fluid and more the next two or so drainings.
ive been driving it more this evening and no issues yet!
What did you use to filter the new ATF?
Probably a good idea to remove the shift solenoid and clean or replace screen.
The shift solenoid I checked while the original fluid was draining. The screen was clean but I blew everything out with some compressed air to be sure. For filtering the fluid I used some paint strainers. They have a really fine mesh in them and they are cone shaped so I just stuck them inside a funnel. It costs less than a dollar for a 4 pack at lowes so I just got a dozen and used a new one each time to keep track of exactly how much debris was getting filtered out each go around.
Try three ATF drain-refill cycles with fresh Castrol ATF for Imports rather than re-using ancient ATF that is clearly trashed. Do it right.
Buying 36 quarts to drain and refill a dozen times would have been hella expensive compared to filtering and repouring the new fluid.
I know 3 times is recommended but the crap clogging the filter was so bad it still wasn't driveable until multiple cycles.
For my situation I would say I did it right. My transmission appeared to be fubar and I got my car back to running like a champ while saving myself the labor and cost of replacing the transmission.
How is doing it wrong right?
Did I miss the part where you fixed the problem?
I think you did. Before I did this my transmission would only function for up to about 30 seconds before it would quit working and act like a standard that had its clutch pedal pushed in. This was not an intermittent issue. This happened every single time I would start the car.
Several people on this forum and elsewhere said the transmission is screwed and to replace it.
After I flushed all that crap out the problem is completely fixed. Ive been driving around all day and have not had a single reoccurrence or any unusual behavior from the car at all.
Re: Automatic transmission slipping, is bad or something simple wrong? (solved)
You might also want to add the Magnefine inline transmission filter.
It will collect a lot more of the gunk over the next while and it's cheap.
That way if any more crap breaks loose the filter can nab it up before it goes back into the tranny.
At 16 bucks and a little 3/8 oil hose, the added insurance doesn't hurt.
Magnefine 3/8 Inch Magnetic Inline Transmission Filter
I put it on my wife's car and the shifting has actually become less clunky over time and now feels a lot more in line with what I expected. This is after doing the 3 and 3 routine and still having hard shifts.
I installed it after the cooler, just before the hard line going over the transmission.
Mind you, this is the 5th gen 92-95. The 6th gen might be different.
Here's the photo:
Here's the photo:
I tried it that way and it still kinked. I think the metal transmission lines on the 6th gen are closer to radiator's nipple and curved near that end as well. Wouldn't allow enough room to make a bend/curve without kinking. Do you have that pic in a DIY thread somewhere? Seems like I've seen that pic before.
I just noticed you have it zip-tied to the splashgaurd.. maybe, I'll try that and see if helps. Thanks
If you have less room to play with, then longer hoses might be required so you can work it in, just for the life of me, I'm not sure where you would stash it.
