b18c in DA ?
b18c in DA ?
ok well I was thinking about just dropping a b18c either jdm GSR or type R, but I was thinking about just using my ys1 tranny(so i don't have to convert to hydraulic). I know it would work, but would the ys1 be able to handle the power and revs of the b18c ?
Re: (LoseRPunKx182)
yeah and also the reason I don't want to change the tranny is because I just installed a new exedy clutch and ACT flywheel 2 weeks ago so it would be a waste.
How does that b18c feel with the ys1 tranny ?
Re: (nickG)
last time i tired to dl the swap guide it wouldnt open. Anyway im in the same situation. I have a S1 tranny but its the long geared version and i just spend $650 on a fidanza flywheel and a CM stage 3 clutch and since i have a 90 the splines are smaller that all the other trannys. Your gonna need a motor, wiring harness for motor, a ecu that matches the motor possibly chipped, OBD conversion harness if you are 90-91 sicne the OBD will possibly be OBD1 motor. Even if its pre-OBD, OBD-1 has more engine managment options than pre-OBD. Im not sure about mounts, you can use ur stock ones??? i dunno but i want one
Location: Good luck to this industry, you're gonna need it.
Re: b18c in DA ? (redDAinteg)
yes...it's a modded hydro trans...you'll be fine
now this is ASSUMING you don't the YS1 long geared (LS trans)
