b18c in DA ?
Old 09-07-2005, 06:22 PM
redDAinteg's Avatar
Default b18c in DA ?
ok well I was thinking about just dropping a b18c either jdm GSR or type R, but I was thinking about just using my ys1 tranny(so i don't have to convert to hydraulic). I know it would work, but would the ys1 be able to handle the power and revs of the b18c ?
Old 09-07-2005, 06:40 PM
Rus1an's Avatar
Default Re: b18c in DA ? (redDAinteg)
it works i just put a gsr in my da
Old 09-07-2005, 06:47 PM
LoseRPunKx182's Avatar
me too...i am upgrading the clutch and flywheel tho
Old 09-07-2005, 10:25 PM
redDAinteg's Avatar
Default Re: (LoseRPunKx182)
yeah and also the reason I don't want to change the tranny is because I just installed a new exedy clutch and ACT flywheel 2 weeks ago so it would be a waste.
How does that b18c feel with the ys1 tranny ?
Old 09-07-2005, 10:28 PM
redDAinteg's Avatar
Default Re: (redDAinteg)
oh and I would need a GSR ecu as well right? and thats about it or am I missing anything ?
Old 09-08-2005, 02:44 AM
nickG's Avatar
http://www.g2ic.com
look in the teg tips for the engine swap guide.
Old 09-08-2005, 03:17 AM
DarkDragon's Avatar
Default Re: (nickG)
last time i tired to dl the swap guide it wouldnt open. Anyway im in the same situation. I have a S1 tranny but its the long geared version and i just spend $650 on a fidanza flywheel and a CM stage 3 clutch and since i have a 90 the splines are smaller that all the other trannys. Your gonna need a motor, wiring harness for motor, a ecu that matches the motor possibly chipped, OBD conversion harness if you are 90-91 sicne the OBD will possibly be OBD1 motor. Even if its pre-OBD, OBD-1 has more engine managment options than pre-OBD. Im not sure about mounts, you can use ur stock ones??? i dunno but i want one
Old 09-08-2005, 04:36 AM
Slain's Avatar
which ys1 do you have the tight geared gsr or the non vtec trans ? the non vtec trans wont leave desirable results
Old 09-08-2005, 05:10 AM
Richard Noggin's Avatar
Location: Good luck to this industry, you're gonna need it.
yes...it's a modded hydro trans...you'll be fine
now this is ASSUMING you don't the YS1 long geared (LS trans)
Old 09-08-2005, 09:29 AM
redDAinteg's Avatar
Default Re: b18c in DA ? (DAantagonist)
yeah I have the ys1 ls tranny, so what would my results be ?
Old 09-08-2005, 11:28 AM
u just wont have the shorter gears...i personally have no problem with mine
JDM_Spec
10-17-2005 10:21 PM
ltho1998
06-22-2005 12:17 PM
ramz7887
11-25-2003 12:02 PM
hybrider
02-17-2002 05:41 PM
Quick Reply: b18c in DA ?
