b18b cams in b18a
Old 07-08-2003, 09:59 AM
88civicHB703's Avatar
Default b18b cams in b18a
i want to know if i drop in b18b cams into a b18a1 engine would it make any different? and also i got my hands on a set of gsr pistons.. would that work in the LS engine too what would i need to get this to run nicely...? thnx guyz plz help a brother out
Old 07-08-2003, 10:35 AM
Eckz2k's Avatar
Default Re: b18b cams in b18a (88civicHB703)
I don't think they would make much of a difference at all......if they did it would make a "thread-like" difference...........
Old 07-08-2003, 01:36 PM
mr.beeks's Avatar
Default Re: b18b cams in b18a (Eckz2k)
grs pistons = higher compression
b18b cams = more fuel more exhaust but the head, intake manifold lacks the flow
so not the full potential unless you port and polish with stage 2 cams.
Old 07-08-2003, 02:38 PM
i got the 94 LS intake manifold would that helps? and AEM cold air.. about the head yes i could get that port and polish.. but would a gsr pistons works in LS block tho if do with what rod..
Old 07-08-2003, 02:43 PM
mr.beeks's Avatar
Default Re: (88civicHB703)
they will fit on stock LS rods with minor mods (of course machine shop will do that)
and it will bump your compression..
and see that baby go..
since you are getting a lot of parts see if you could get a gsr or b20 oil pump and
water pump..
kinda of building an LS/vtec.
Old 07-08-2003, 03:31 PM
but i think modded LS should do for basic N/A setup.. just to pack a punch... cant risk LS/vtec yet... and i heard LS could pack alot of torque is htis true?
Old 07-08-2003, 03:34 PM
mr.beeks's Avatar
naturally aspirated b18a
will do on the mid and high end lossing power on the low end
but my point was just to upgrade water and oil pump.
just try to match it up to a gsr or b16 tranny.
Old 07-08-2003, 03:41 PM
my point exactly im still searchin for gsr tranny.. after that i'll be set.. so u sayin piston upgrade cam.. and water and oil pump? and all them good bolt on parts
Old 07-08-2003, 03:45 PM
mr.beeks's Avatar
yeap thats right
I forgot to mention to shot peen your rods
or get upgraded rods.
Old 07-08-2003, 03:49 PM
too?
Old 07-08-2003, 03:55 PM
mr.beeks's Avatar
its like trying to eliminate any weak link so it will last..
Old 07-08-2003, 04:01 PM
eagle LS rods woud do or do i have to get it custom.. i dont know what shortpender rod mean
Old 07-08-2003, 04:07 PM
mr.beeks's Avatar
shot peened = a bunch of pins hitting a surface with tremendous pressure
therefore streghtening the surface.
but aftermarket ls rods are fine...
Old 07-08-2003, 04:11 PM
i just found a complete b20z head would that help performance any?
Old 07-08-2003, 04:15 PM
mr.beeks's Avatar
to tell you the truth I have not messed around any b20z
so I dont know if it lines up or any other mods need to be done...
Old 07-08-2003, 04:17 PM
hmm yea i heard they do bolt up... but i wonder if it give any extra power and torque with much mod...
Old 07-08-2003, 04:22 PM
mr.beeks's Avatar
just put it this way
it has to feed a bigger bore.
therefore a better flow is needed.
so my best educated guess it will save you the port and polish of the b18a
Old 07-08-2003, 04:24 PM
yea p&p is expensive... around my area..$300-$400
Old 07-08-2003, 04:26 PM
mr.beeks's Avatar
is this port and polish flow tested before you
receive it?
if it is, its not a bad price...
Old 07-08-2003, 04:28 PM
i know a local shop owner is a personal friend of my cousin we got our **** done over there alot...
Old 07-08-2003, 04:46 PM
Yougod's Avatar
Default OT (Eckz2k)
Sorry for posting on this thread but I've been trying to get ahold of Eckz2k. Can someone IM him and tell him to contact me on AIM? I have only been registered on Honda-Tech for a week or so I can't use the IM feature just yet. Again sorry, if this is inappropriate... then disregard.
Old 07-08-2003, 04:54 PM
im lost...
Old 07-08-2003, 05:01 PM
Yougod's Avatar
He has like the 2nd or 3rd post on this thread. thanx
JCurry
13
06-06-2010 07:57 PM
dmpd_ef
12-05-2007 02:58 PM
typeR564
12-09-2004 03:12 PM
zCivic
07-01-2003 06:21 PM
elmalouno
01-28-2003 09:57 PM
Quick Reply: b18b cams in b18a
