B18A and B18B heads
Old Jun 30, 2003 | 07:27 PM
zCivic's Avatar
Default B18A and B18B heads
I know there both PR4 head codes but are there any other differences between them. Can you place a B18A head on a B18B block and keep aprox same compression ratio. Are there any problems with piston to valve clearances. Are the cams the same lift/durations or is one gonna be better then another?
Old Jun 30, 2003 | 08:22 PM
sgT's Avatar
sgT
Default Re: B18A and B18B heads (zCivic)
afaik the heads themselves are identical. differences are in the valvetrain from 1992+ vs 1990-91
Old Jun 30, 2003 | 08:28 PM
.RJ's Avatar
.RJ
Default Re: B18A and B18B heads (sgT)
also the manifolds are different from 90/91 and 92+. The later manifolds flow better.
99+ B20Z cams (stamped P75) are also the same as 92+ LS cams, but have a few more degress of duration on the intake cam.
RJ
Old Jul 1, 2003 | 04:39 PM
zCivic's Avatar
Default Re: B18A and B18B heads (.RJ)
kewl so seeing I have the B18B cams and intake mani just use throw those in/on the B18A head and its all good
Old Jul 1, 2003 | 05:46 PM
StorminMatt's Avatar
Actually, the 1990-1993 (B18A) head has smaller intake ports.
Old Jul 1, 2003 | 06:21 PM
zCivic's Avatar
hmmm thats strange about the valves b/c went to acuraautomotiveparts.org and they both were listed as the same p/n for 92's and 95 just to throw out some years??? are you sure about the differences in valves??
boostedb20z
Feb 20, 2008 06:09 PM
hgw84
Mar 7, 2006 06:07 PM
stareatsun
Oct 4, 2004 05:02 AM
haggar
Aug 15, 2003 04:04 PM
