MC, Brake booster question
i have a 93 sedan which im gonna upgrade all the brakes from an integra gs. i am confused on which mc, booster and proportioning valve to get. if i use the 15/16 MC off a 91 Civic sedan EX can I keep my stock booster? Will it make a difference if I install the mc and booster from an Rs (non-abs)? As the proportioning valve which one bolts on best? thanks.
Re: MC, Brake booster question (93civicsedan)
yes you can use the 91 ex MC, but if you use the RS MC you have to switch the booster too, because the mount point on the RS are completly oppiste of the civic unit.
any 40/40 pro valve will work, just make sure if you have abs you get an abs one and if you don't you get one with out an abs
Re: MC, Brake booster question (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">yes you can use the 91 ex MC, but if you use the RS MC you have to switch the booster too, because the mount point on the RS are completly oppiste of the civic unit.
I thought the RS was the same as the Civics, I know the GSRs is the other way, the RS is supposed to be a direct bolt on to the EX one.
Re: MC, Brake booster question (92b16vx)
no no no no no no no no no no no no no no no no no no no no no no no no no no no no, i have an RS MC setting on the floor next to my car in my garage, the bolt holes are different. you must use the BOoster from an integra.
b18c5eh2 has discussed this in all of his thread about break swaps, check in the FAQ
i don't think it will make a difference. and i would guess that it would be minimil if any.
i went with the RS one because it was in stock and my booster was on its way out
rukawa1one
09-18-2003 05:25 PM
