abs?
Old May 16, 2007 | 11:40 AM
Krayzielix's Avatar
Default abs?
i just changed my axle..n now my abs light comes on anyone know why is there a difference n abs n non abs axles..will this effect my braking or anything?
btw 99 gsr abs
Old May 16, 2007 | 12:00 PM
teg97's Avatar
Default Re: abs? (Krayzielix)
the abs axle will have a ring on the outer axle shaft and thats what abs spped snsr reads. this will affect your abs unit and it will not work properly if it doesn't read the one axle
Old May 16, 2007 | 01:45 PM
Dogginator's Avatar
Daisy... Daisy...
Pull the ABS codes like you would a CEL (see the FAQ thread). It could be the axle or it could be a coincindental problem. Look for the cog ring on the axle.
Old May 16, 2007 | 09:43 PM
Krayzielix's Avatar
axle is already installed..so i dont have abs now?how do u pull an abs code..
Old May 17, 2007 | 03:43 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Krayzielix)
From the Integra forum FAQ thread:
https://honda-tech.com/zerothread?id=978933
Just read the ABS light for the codes.
Old May 17, 2007 | 07:41 AM
nWilk666's Avatar
Default Re: (Dogginator)
question about pulling abs codes. when i go to pull the code i have a cel on too, so all it does is bling the cel not the abs, how would i go about getting the abs to flash?
Old May 17, 2007 | 08:52 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (nWilk666)
If there are stored CEL and ABS codes, they both should blink their codes.
Old May 17, 2007 | 03:56 PM
nWilk666's Avatar
well its a solid abs light on any ideas?
Old May 18, 2007 | 03:48 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nWilk666 &raquo;</TD></TR><TR><TD CLASS="quote">well its a solid abs light on any ideas?</TD></TR></TABLE>
That usually means that there are no stored codes. Is the ABS light on constantly while driving or does it blink every once in a while? The ABS computer may be the culprit.
Old May 18, 2007 | 11:07 AM
nWilk666's Avatar
constantly on but every now and then it will go off but soon as i step on the brakes.. its back
Old May 19, 2007 | 04:50 PM
Dogginator's Avatar
Daisy... Daisy...
You can try to clear the ABS memory by pulling the underhood fuses near the ABS modulator. See if the light returns and try to pull the codes again.
EG civic
Nov 11, 2020 11:44 PM
j0keefe21
Feb 14, 2009 08:13 PM
felixjr18
Dec 21, 2008 07:22 PM
94_teggy_rs
Jan 28, 2008 08:36 PM
fakemike
13
Feb 20, 2005 04:16 PM
