camshaft problem
Old May 17, 2007 | 10:33 PM
krazeenoy's Avatar
Default camshaft problem
i just bought a JG camshaft for my 93 integra...when i put it on it ticks...do i need to adjust any valves?
Old May 18, 2007 | 09:16 PM
krazeenoy's Avatar
Default Re: camshaft problem (krazeenoy)
bump...
Old May 19, 2007 | 02:49 AM
mike5809's Avatar
Did you adjust them right when you put them in, and did you adjust them to the cam specs? Aftermarket cams need different valve adj than stock.
Do a valve adj should fix it at least most of it. With an aftermarket cam it will be louder so you can expect some tick.
Old May 19, 2007 | 07:27 AM
Sam92Teg's Avatar
You have to adjust the valve lash any time you swap in cams, especially if they have different size lobes. If you didn't, your lucky the rocker arms didn't bind when you torqued down your cam caps.
Old May 19, 2007 | 12:38 PM
krazeenoy's Avatar
Default Re: camshaft problem (Sam92Teg)
how do i do a valve adjustment for the jg camshafts?
Old May 19, 2007 | 12:52 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazeenoy &raquo;</TD></TR><TR><TD CLASS="quote">how do i do a valve adjustment for the jg camshafts?</TD></TR></TABLE>
just like you do on stock cams. same spec.
Old May 19, 2007 | 04:50 PM
ls19integra95's Avatar
Default Re: camshaft problem (Kangpreza)
also what stage cam is it because depending on what size cams you put in even after valve adjustment you may still hear a slight ticking... mine does the same thing even after we had a valve adjustment done
Racewerkz
Jan 26, 2011 07:55 AM
krazeenoy
Jun 12, 2007 06:26 PM
Kovatch EG
Jul 15, 2006 12:13 PM
Squrtin DC2
15
Apr 22, 2006 06:35 AM
kwik93si
May 2, 2003 03:58 PM
