Axle replacement, ABS or not?
I have a B18c1 in my 92 hatch dx (no ABS). The engine is from a GSR with ABS.
I have a torn boot and I was looking to replace the axle. Can I use a non-ABS axle for the replacement?
TIA
BTW Split/Quick boots are trash
Modified by fakemike at 11:50 AM 2/16/2005
TIA
1 Post
Re: (EG_Black_Hatch)
no you can just put it on. I had abs front axles on my car after the swap now I have 1 abs and one non abs it makes no difference whatso ever. just put em on there.
Re: (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Can't you remove the abs rings by tapping them off with a hammer?</TD></TR></TABLE> Do not remove the ring gear. Just leave it on if you do not have abs. Either axle will work (abs or non-ABS). If you remove the rings you might not get the core charge back.
Location: hittin corners so hard you can taste my rims..
Re: (B18C2_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C2_sedan »</TD></TR><TR><TD CLASS="quote"> Do not remove the ring gear. Just leave it on if you do not have abs. Either axle will work (abs or non-ABS). If you remove the rings you might not get the core charge back. </TD></TR></TABLE>
yes... dont' remove the ABS ring, it will NOT affect a NON ABS vehical in anyway. either or will work.
Re: (slowdx9585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx9585 »</TD></TR><TR><TD CLASS="quote">no abs, no need for abs axle.IF you had abs and put a non abs axle in your car your abs light would come on.</TD></TR></TABLE>
God dammit, i think thats what this mechanic did to my accord.
97 v6, right axle broke. Had abs before taking it in. He replaced it, now the light is on. Any way to fix, other then get another axle? is my abs still there?
