About my starting problem...
Old Feb 4, 2002 | 01:04 PM
RuskeR's Avatar
Default About my starting problem...[pic]
Well we thought maybe the engine was just flooded and that's what the guy at acura was also thinking but, after trying a few more times starting it I just figured let acura themselves try. I sat there for about a minute with the accel. pedal all the way down to let anything drain. And then tried to start it will the pedal all the way down to the floor. Never knew this is how you try to start a flooded engine but, this is what he was having me try. Learn something everyday I guess. So, it should get there in about 2 hours. A very loooong 2 hours.
So sad that this is my first pic I've posted of my car on here. lol
my original post about the problem: https://honda-tech.com/zerothread?id=121688
[Modified by RuskeR, 2:08 PM 2/4/2002]
Old Feb 4, 2002 | 01:07 PM
ingrate's Avatar
25 Year Member
Default Re: About my starting problem... (RuskeR)
fuel injected engines don't "flood." only carbureted engines do that.
Old Feb 4, 2002 | 01:09 PM
RuskeR's Avatar
Default Re: About my starting problem... (In7egrity)
Well that's what he was saying.. I was like uh ok.
Old Feb 4, 2002 | 01:10 PM
ingrate's Avatar
25 Year Member
after reading your other thread, i think it's the battery. that should be the first thing you should check out. have the dealer test it. good luck
Old Feb 4, 2002 | 01:14 PM
RuskeR's Avatar
So why would everything still work? windows, radio, etc..? I didn't want to mess with it too much since it is still under warranty. Cause the engine is cranking over but, just doesn't fire up.
I don't know excatly he meant by "flooded". He says he's seen this problems happen usually in the winter.
Old Feb 4, 2002 | 01:33 PM
ingrate's Avatar
25 Year Member
i'm not an expert with carburetors, but i'll try to give you a really basic explanation of flooding.. in a carbureted engine, the gas pedal releases fuel whenever you push the pedal. if the car is off and you push the gas pedal, it'll flood up.. the engine will be hard to start, so that's why you hold down the pedal when trying to start the car. to drain it out sort of..
in a fuel injected car, the gas pedal really only opens up the throttle plate. the ECU and air sensors are what determines when and how much fuel is used.
Old Feb 4, 2002 | 01:40 PM
RuskeR's Avatar
I thought it sounded weird because I also have an old 83 civic and sometimes I need to pump the gas to get it started but, I'd never even think to try that with my teg. But, he told me to try that and I asked him if that even works on a FI car. I didn't really care at this point. I just want damn car back, ya know. So, hopefully it turns out to be something that's covered.
Old Feb 4, 2002 | 01:46 PM
Phat Corolla's Avatar
New User
did you check your dist. cap and rotor? How about your ignitor?
Old Feb 4, 2002 | 01:50 PM
RuskeR's Avatar
Default Re: About my starting problem... (Phat GS-R)
yeah, and checked all fuses.
Old Feb 4, 2002 | 01:51 PM
New User
Oh bummer. I have no more input then. Sorry...
Old Feb 4, 2002 | 01:52 PM
RuskeR's Avatar
Also, the car JUST had it's 30,000 service at the same dealer. Thanks for replying though
[Modified by RuskeR, 2:53 PM 2/4/2002]
Old Feb 4, 2002 | 02:45 PM
non-VTEC's Avatar
that's so wrong........i've seen ALOT of fuel injected engines get flooded......
Old Feb 4, 2002 | 02:53 PM
ingrate's Avatar
25 Year Member
Default Re: About my starting problem... (non-VTEC)
really? was it by pushing down on the gas pedal while the car was off? i've never seen it happen in my experience
Old Feb 4, 2002 | 03:01 PM
RuskeR's Avatar
Well he said for me to hold the accel. down ALL the way for a minute. And when starting it I need to hold it all the way down again. I was ready for the car to start and go crazy.
Old Feb 4, 2002 | 03:17 PM
non-VTEC's Avatar
faulty ignition system and/or ignitor.......no spark= flood the cylinders.....and it's really hard to dry it out after.....
Old Feb 4, 2002 | 03:25 PM
ingrate's Avatar
25 Year Member
learn something new everyday
Old Feb 4, 2002 | 03:30 PM
New User
Yeah, I didn't know that Fuel Injected cars flooded either. I was told that it's bad for injectors if you run out of gas. I called BS on the guy that told me, but is that true?
Old Feb 4, 2002 | 03:49 PM
ingrate's Avatar
25 Year Member
well there are deposits at the very bottom of the gas tank.. assuming your fuel filter becomes all clogged up with crap, it makes sense. i personally wouldn't try it
Old Feb 4, 2002 | 08:39 PM
RuskeR's Avatar
Kinda heard the same thing but, all I heard it does is just gets them dirt quicker if you always let your tank run to almost empty. I did that alot in my old car, but chevron gas always made it run better. Must be that "techron" haha
Old Feb 5, 2002 | 05:27 AM
NoSoup4U's Avatar
Default Re: About my starting problem...[pic] (RuskeR)
If the car tries to start but never turns over, it may be your fuel pump. Let us know what the dealer says.
DJLikwid
Honda Civic (2006 - 2015)
May 30, 2011 09:31 AM
fireflare
Sep 30, 2009 09:48 AM
Bizarre
Aug 17, 2003 03:09 PM
integra80
Nov 4, 2002 03:07 PM
Jay_Miyazaki
Feb 17, 2002 11:44 AM
