94 Ls odometer doesn't work. Everything else does
Old Oct 28, 2012 | 09:47 AM
  #26
fcm's Avatar
fcm
Old Fart
Default Re: 94 Ls odometer doesn't work. Everything else does
Google is your friend... http://www.google.ca/search?q=94+int...L4GIiwK5iIHIAQ 94
Old Oct 28, 2012 | 11:06 AM
  #27
el crapitan's Avatar
hot damn. there ya go. at your fingertips.
i guess a case of beer could have even bought a haynes manual. which, although not the optimal manual, would have sufficed.
now you can go through and test for continuity between the vss and cluster for starters
actually, check your vref and reference ground at the vss first
as mentioned previously, a multimeter will be required
Old Oct 28, 2012 | 11:11 AM
  #28
check all your fuses first too. use the test light for that. under hood and in cabin.
although it's unlikely to be a fuse. since the problem was first intermittent
Old Oct 28, 2012 | 11:21 AM
  #29
also forgot to mention that since the circuit goes through the ecm, you must test continuity in 2 parts so the ecm can be disconnected. otherwise damage to the ecm could occur. so look at the configuration of the circuit to determine where your test points will be
Old Oct 29, 2012 | 03:25 PM
  #30
jdmturboitr's Avatar
Hmmmmm :/
Old Oct 31, 2012 | 09:56 AM
  #31
Ok I looked at that wiring diagram, I can't read Chinese. but nah, I'm not understanding it. I cut the plug that goes to top of sensor and ran the 3 wires directly to the sensor. The plug was a lil corroded and I couldn't get into the pins well enuf to clean it so I cut it off. Just trying to figure out problem. I'll replace the plug later. But it still does not work. I unplugged ecu, turned ignition to on position, and the sensor is getting power. As well as a good ground. I'm gonna attempt ANOTHER known working sensor...just wanted to update this.... smdh
HighCardAce
Nov 5, 2009 01:42 PM
syknxv3
Sep 15, 2008 01:04 PM
andyb52182
Aug 31, 2008 09:40 PM
JOSHGLISSEN
Aug 29, 2008 10:16 AM
BReK.One
Nov 17, 2004 12:24 AM
