93 Integra GSR passenger side window doesn't work!
I have a 1993 Integra GSR and the driver side window works fine, but the passenger side does not work at all, the switch on the passenger side and the driver side does not make it work, so is it possible it is a motor or something else is broken, I am new to these "luxury's" so any help would be good
Re: 93 Integra GSR passenger side window doesn't work! (jdmcivicferio)
Same thing happend to me. I took apart my driver side door panel. Popped the harness out and plugged it back in. Started working again
im not sure about the older integra's but the window regulators go bad in alot of acura's.
does the motor run when you push the button, start there.
Re: (jdmcivicferio)
the regulator is in the door behind the panel, but i would start with the easy stuff like fuses under the dash. also check the switch on the d/s door that locks the pass. window, if it has that option. if none of that helps then you need to check for power at the regulator and the switch.
chris4x4
13
05-08-2011 10:39 AM
commotion
07-19-2006 08:51 PM
