92 DA cooling system problems
Old 05-01-2013, 04:45 AM
swindian1991's Avatar
Default 92 DA cooling system problems
I have a 92 LS, I just recently installed a new thermostat because my lower hose wasn't getting hot and my temp Hague was fluctuating. I replaced it and now my gauge works fine.but the lower hose will still not get hot. This.morning I check to see if there was air in the system and I opened the bleeder valve, coolant came out when I had the cap.off but when I put the cap.on and let it warm up again the nothing came out.of the bleeder valve. Hose will still not get.hot. Any ideas what this could be? A faulty thermostat? the fans won't kick on also but haven't tested to see if it a bad motor yet.
Old 05-01-2013, 05:30 AM
el crapitan's Avatar
Default Re: 92 DA cooling system problems
does the lower hose get warm? or does it stay cold? it shouldn't get hot. just warm. where does the needle on the gauge sit?
Old 05-01-2013, 07:55 AM
Blackhalo6's Avatar
Sounds like air in the system. You need to purge it. When its warmed up and cap is on coolant should come out of the bleeder.
Old 05-01-2013, 11:33 AM
While it is running bleed it? The temp gauge stays in the middle, Regs operating temp.
Old 05-01-2013, 02:33 PM
Blackhalo6's Avatar
yea to bleed mine ive just left it running and cycled the bleeder periodicly to bleed air as it got trapped in the system.
civisedan
11-26-2011 07:12 PM
ek_silverback
12-22-2008 09:34 PM
No
03-07-2006 12:13 AM
simplypinoyy
23
08-06-2004 03:06 PM
superstud
03-14-2004 08:54 PM
Quick Reply: 92 DA cooling system problems
