9005 Headlight Conversion Question: HELP!
Old May 11, 2002 | 07:29 AM
OneBadDC2's Avatar
Default 9005 Headlight Conversion Question: HELP!
So far i have completed each step except being able to remove the guides inside the lightbulb socket, I do not have a dremel, so please advise me on what to do. What did you guys use to remove the guides. Please post any suggestions. Here is a picture of the guides.
Old May 11, 2002 | 07:45 AM
ragejed's Avatar
Default Re: 9005 Headlight Conversion Question: HELP! (OneBadDC2)
search, but ya, use a soldering iron
Old May 11, 2002 | 07:59 AM
LostGsr's Avatar
Dremel, soldering iron, or like one of the members here said "hot glowing red knife" Goodluck
Old May 11, 2002 | 08:29 AM
OneBadDC2's Avatar
Default Re: 9005 Headlight Conversion Question: HELP! (LostGsr)
Ok, I just used a soldering iron and was able to melt away the guides. I tried to clean it up on the inside but still some crap left in there. I installed them and they light up properly, but since it is day time I will be able to tell the difference. Now I have one more question:
-Have there been any problems with this conversion? Melting the Sockets and applying any damage to the stock wiring harness, If so, i will go back to the stock light bulbs, i do not want to have a messed up lighting system on a NEW car.
Old May 11, 2002 | 08:56 AM
khoalie's Avatar
i doubt there will be any problems.
what kind of bulb are you using.
stock ones are like 60 and that is considerably less than the 90W blue bulbs
peolple use the high *** wattage bulbs on integras w/no problem so you should be ok
Old May 11, 2002 | 09:34 AM
GS-R Jay's Avatar
I used a small file and just filed those things out. Only took me about 5 min per bulb. Very easy.
Old May 11, 2002 | 10:43 AM
Al Bundy's Avatar
Default Re: 9005 Headlight Conversion Question: HELP! (GS-R Jay)
I just bought 9005 sockets and wired it in so its easier to change next time when a bulb burns out
Old May 11, 2002 | 05:31 PM
Weston's Avatar
I used my swiss army knife to just cut the center thing out. Worked really well.
Old May 11, 2002 | 05:35 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: 9005 Headlight Conversion Question: HELP! (Weston)
Its not that hard to cut plastic.. you prolly could of bitten the tabs off... And feel free to use the search tool next time.
Old May 11, 2002 | 07:43 PM
01SilverGSR's Avatar
I also just wired in some 9005 sockets instead of messing with the bulb.
Old May 11, 2002 | 08:29 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 9005 Headlight Conversion Question: HELP! (01SilverGSR)
you can also widen the slot in the 9006 harness to accept either 9005 or 9006 bulbs w/o modding them.
Old May 12, 2002 | 01:00 AM
asianautica's Avatar
Default Re: 9005 Headlight Conversion Question: HELP! (PatrickGSR94)
All i did was just stuff it in. It stays in pretty snug and tight. No cutting or anything. just jam it in.
Old May 14, 2002 | 12:19 PM
xero-cool's Avatar
Default Re: 9005 Headlight Conversion Question: HELP! (asianautica)
What about using the NAXOS 9005 100W bulbs for the conversion?
Will I fry my harness?
Old May 14, 2002 | 01:20 PM
Community Builder
Default Re: 9005 Headlight Conversion Question: HELP! (xero-cool)
most likely.. high wattage bulbs are ghey
crxmadman
Oct 8, 2003 12:38 PM
King_j
Apr 7, 2003 11:41 AM
rollin_DC4
Apr 2, 2003 01:21 PM
weakGOODJunKieS.com
Mar 9, 2003 07:26 PM
5-SpeedFreak
Nov 30, 2002 03:46 PM
