5 lug conversion?
Old Feb 10, 2006 | 07:51 AM
silentdeath12886's Avatar
Default 5 lug conversion?
i want a 5 lug conervsion without having to buy the whole brake and axle assembly is possible...i was thinknig of buying OEM type-r 5 lug wheel hubs...i know i will need to replace the rotors and would like ITR calipers...is this format compatible with an LS? will i need new axle? will the hubs fit onto my LS axle?
Old Feb 10, 2006 | 07:55 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: 5 lug conversion? (silentdeath12886)
Three short topics on 5lug, check it out and search some,
the last one said something about switching just the hub I think.
https://honda-tech.com/zerothread?id=1365770
https://honda-tech.com/zerothread?id=1314195
https://honda-tech.com/zerothread?id=1369821
Old Feb 10, 2006 | 07:57 AM
nickG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 &raquo;</TD></TR><TR><TD CLASS="quote">i want a 5 lug conervsion without having to buy the whole brake and axle assembly is possible...i was thinknig of buying OEM type-r 5 lug wheel hubs...i know i will need to replace the rotors and would like ITR calipers...is this format compatible with an LS? will i need new axle? will the hubs fit onto my LS axle?</TD></TR></TABLE>
how can you do the itr conversion without buying the "brake assembly" but you would still like the itr calipers...
theres ways to get bigger brakes w/o doing the 5 lug..
the main benefit of the itr 5 lug is the itr brakes..
Old Feb 10, 2006 | 08:32 AM
the 5 lug is mostly for cosmetic purposes, and by brake assemly i mean all the mounts and arms etc..i couldnt think of a gerneal word for it
Old Feb 10, 2006 | 09:11 AM
CNSK's Avatar
Default Re: (silentdeath12886)
thats what I always wonder.....what if i just take the 4 lug hub out and press in the 5 lug hub(oem type R) with 5 lug rotors(replica brembo) and call it a day. ?? Reason for being was when i kicked out my hub to replace the wheel stud I wonder if it will work......i dont really care if its functional....cosmetics is what i want........
Old Feb 10, 2006 | 12:58 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (CNSK)
ladies ladies, chill.
Basically, if you want a 5-lug hub you almost certainly gonna have to have bigger brakes. So....press out your 4x100 hub, press the ITR hubs into those bearings, and get ITR or bigger brakes, the front ITR calipers/rotors, and the back, ITR calipers/rotors. You don't have to get a full "5-lug conversion" as many idiots sell the WHOLE suspension, like the knuckles, trailing arms, UCAs, LCAs, etc.
Old Feb 11, 2006 | 06:27 AM
CNSK's Avatar
Default Re: (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">ladies ladies, chill.
Basically, if you want a 5-lug hub you almost certainly gonna have to have bigger brakes. So....press out your 4x100 hub, press the ITR hubs into those bearings, and get ITR or bigger brakes, the front ITR calipers/rotors, and the back, ITR calipers/rotors. You don't have to get a full "5-lug conversion" as many idiots sell the WHOLE suspension, like the knuckles, trailing arms, UCAs, LCAs, etc. </TD></TR></TABLE>
so then it is a must to buy the itr calipers to fit the rotors becuase its bigger rotors correct? so then you dont even need the whole suspension, lca's, knuckles..etc?
Old Feb 11, 2006 | 07:59 AM
* B A N N E D *
Default Re: (CNSK)
https://honda-tech.com/zerothread?id=1513752&page=1
Read this, should help. And no, you don't need the ENTIRE suspension like everyone says, however if you go 5-lug you will be doing a brake upgrade, because...well I know Honda brake systems and I'm not aware of any 10.3" brake setup thats 5-lug, the smallest 5-lug setup is the ITR brake setup, so you'll need somethin else.
Some do a 5-lug brake setup for the bling, but some do it cause they want bigger brakes.
If you want bigass brakes, you can stay 4x100, ya don't need a 5th lug and new wheels.
obviousBOY
Suspension & Brakes
Mar 30, 2016 12:27 PM
vu337
Apr 27, 2009 04:40 PM
bmxer
Aug 31, 2008 11:35 AM
samnizzle
Honda Civic (2001 - 2005)
17
Jul 27, 2008 07:43 PM
DC4KiD
Mar 7, 2005 09:32 AM
