Has anyone had any problems with weldless oil return bulkhead connectors?
Old Feb 14, 2003 | 09:37 AM
krazy's Avatar
Default Has anyone had any problems with weldless oil return bulkhead connectors?
i was gonna install my own turbo, and i have no access to a welder or do i know how to weld...haha. anyway i was wondering if anyone has experience or is using a AN type bulkhead connector such as this:
if so, do you have any problems, what could be the pros and cons, and could i safely use this with some gasket sealer and tight lock nuts?
thanks in advance.
krazy
Old Feb 14, 2003 | 09:38 AM
falcongsr's Avatar
What is this crap?
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (krazy)
whats the inner diameter of that fitting?
Old Feb 14, 2003 | 09:56 AM
krazy's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (falconGSR)
hmmm thats a good question. i dunno though. i just know they come in -6AN,
-8AN, -10AN, and -12AN.
krazy
Old Feb 14, 2003 | 10:36 AM
Smashback's Avatar
Go with -10 but get the steel one and have a muffler shop weld it for you.
Old Feb 14, 2003 | 11:30 AM
krazy's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (Hatchblack)
so im assuming my idea is a bad idea right? i mean i can go out and get it welded, but i was just searching for a quick effective solution for those who cant weld or some how cant afford to stop, drive out and get it welded. i may just ask a friend for a spare oil pan, weld it, and swap.
so this is a no go then rite? and i should weld. oh and another thing, the max rev turbo kit comes with a rubber oil return line, is this ok to use, or should i get steel braided hose? thanks
krazy
Old Feb 14, 2003 | 11:41 AM
SEFIxCivic's Avatar
it will work. thats how my friend has it on his car, he used honda bond as the seal, and there's no leaks. however, that bulk head is too long and you're going to need to cut a lot of it off. you only need enough to thread the lock nut on and thats it.
Old Feb 14, 2003 | 01:10 PM
krazy's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (SEFI8LOxCivic)
sounds good. ill do this then. if it leaks, ill just weld it later on. no biggie. thanks
krazy
Old Feb 14, 2003 | 01:39 PM
2000GSRT's Avatar
Get these parts:
981510 -10 Union-Male A.N. TO A.N. Adapter
992410 -10 A.N. Bulkhead Nut
178014 -10 Stat-O-Seals
I got mine from http://www.anplumbing.com no probs so far.
Old Feb 14, 2003 | 03:00 PM
krazy's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (2000GSRT)
Get these parts:
thanks. thats a bad *** site. better than summit.
krazy
Old Feb 14, 2003 | 03:11 PM
Sonny's Avatar
I used that type of fitting on my oil pan (-10 AN) and cut the back off. I used Stat-O-Seals and Hondabond. The guys at amstreetrod.com said that it should seal no problem.
Pics:
With the -10 AN fitting, you will need to drill a 7/8" hole in the pan. It is REALLY hard to find a nice 7/8" bit that doesn't cost an arm and a leg. I would HIGHLY recommend a "unibit" drill bit. You can get them new on eBay for about 20 bucks and they drill a perfectly round hole (which is essential for a good seal) in sheet metal.
Sonny
Old Feb 14, 2003 | 03:17 PM
TurbothisLS's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (Sonny)
nice work
Old Feb 14, 2003 | 03:24 PM
krazy's Avatar
wow.... nice work. thanks man. i will definately do that. good tip on the bits too, ive been meaning to get a set of unibits.
krazy
Old Feb 14, 2003 | 08:02 PM
1.8T_EG's Avatar
... wow!... nice setup... i am hoping to switch from my rubber hose and clamp setup to something similar to this...
Old Feb 14, 2003 | 09:11 PM
earl's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (1.8T_EG)
This is the set-up you want
Old Feb 15, 2003 | 06:23 AM
99lspwr's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (earl)
I use the greddy fitting and some hondabond. Worked perfect. You can still use there parts even if u dont have the greddy kit. It comes with the 2 inch spout to hook up your return line and a plate that bolts through the inside of the pan, along with the hardware....Works perfect if done correctly...
Old Feb 15, 2003 | 12:18 PM
krazy's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (99lspwr)
yea ive seen the greddy "spout" doesnt look too reassuring. if something were to hit that spout, the mounting might break off, and then u will have a whole lot of trouble. greddy reccomends welding those as well. i think what earl and the others posted are what im gonna stick with. looks good, gets the job done and its cheap. thanks guys.
krazy
Old Feb 15, 2003 | 01:33 PM
dirtySOHC's's Avatar
will this same set up work for a d16y8 pan?
Old Feb 15, 2003 | 01:48 PM
krazy's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (dirtySOHC's)
i dont see why it shouldnt. go for it buddy! ill be doin the same.
krazy
Old Feb 15, 2003 | 02:25 PM
Sonny's Avatar
My pan in the pic is a D16A6 pan. The D16Y8 pan is similar. You will need to grind the windage tray a little to get the fitting to clear. Or you can just raise it up some and not worry about it.
Sonny
Old Feb 17, 2003 | 02:11 PM
b18cya's Avatar
subscribing
Old Feb 17, 2003 | 02:36 PM
LSiTurbo's Avatar
Dont use these the will come loose and leak, maybe if you silicone the **** out of it! i have used these... no good...
Old Feb 17, 2003 | 03:50 PM
SiRkid's Avatar
Default Re: Has anyone had any problems with weldless oil return bulkhead connectors? (LSiTurbo)
installer problems maybe?
.kyle
Apr 10, 2006 04:59 PM
Rory Breaker
Nov 6, 2003 12:05 PM
FastNFurious
May 24, 2003 09:43 PM
slow02ss camaro
Mar 20, 2003 01:01 PM
Evil EG
Apr 3, 2002 07:30 PM
