Big Pauter Rod Problem
Old 08-31-2014, 07:48 AM
1HGEJ2's Avatar
Default Big Pauter Rod Problem
Hello HT
I have a big problem. Bought an engine with 2 different Pauter rods.
2 wheight 560gr and the other 566gr! So 6 gramms more
I have some pics
Why is that so? Did pauter changed the design? which is the newest rod? which the older model? i Think i cant rev the engine to 10K rpm with 6gr different on the crank :/
Old 08-31-2014, 09:08 AM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Big Pauter Rod Problem
So...take it back to the person you bought it from.
Old 08-31-2014, 09:19 AM
met
met's Avatar
And or call Pauter, they are good people. I have had good experiences with them.
Old 08-31-2014, 11:33 AM
NotARaCist's Avatar
Those also look like X beams, which are STUPIDLY expensive, and considering OP said that s/he "bought an engine with two different rods", I'd definitely go back to the person I bought the engine from.
Old 08-31-2014, 01:35 PM
1HGEJ2's Avatar
ive emailed them today. hope for some answer. ive checked the hompage.
i cant bring it back. i bought this engine a few years ago. and it never run
Old 08-31-2014, 03:28 PM
JRCivic1's Avatar
Balancing a rotating assembly is always a good idea with any high performance engine. Take the rods and pistons to a machine shop and have them balanced. This will make all of the rods look uniquely different, so it will be irrelevant which pair is new or old. One should never assume that a set of pistons or rods weigh the same and are a "balanced set" because it is quite common that they are not.
Old 08-31-2014, 03:52 PM
1HGEJ2's Avatar
mmh the other problem is, the small end have a width of 18mm and the other 22mm. u can see it on pic 4.
Old 08-31-2014, 04:55 PM
NotARaCist's Avatar
Translation: It's the wrong ******* rod. Take it back to the person you bought it from.
Old 08-31-2014, 05:00 PM
Moderator in Chief
Muckman's Avatar
You have two different rods or at least two different generations of the same rod.
Old 09-01-2014, 12:21 AM
JRCivic1's Avatar
Obviously, attempting to sort this out with replacements from the vendor would be the first step, but it doesn't change the idea of verifying the weight balance of the parts. I didn't notice the difference of the pin end width in your photos, (although I did notice the cast flat and small bored hole in the Pin end) but this would be a great place to remove the additional weight since those two rods appear to be the heavier ones. Any competent machine shop can narrow the pin end of the rods to that of the other two.
I am just saying you have options if the vendor doesn't come through... you can get past this issue. No worries.
Old 09-01-2014, 12:25 AM
1HGEJ2's Avatar
I dont know if pauter started a new generation. Its all for b16a but 4 rods and 2 are different.
Old 09-01-2014, 01:07 AM
1HGEJ2's Avatar
hey muckman.
do u have some pics of ur pauter rods? u and me have older laskey,benson block without a benson logo on the block.
u have the same cap
Old 09-01-2014, 09:50 PM
Who is Mr Robot?
wantboost's Avatar
Skip the email and call them... companies like pauter receive countless emails each day and it could take weeks to get a reply... you'd get better help over the phone and you can email photos directly to the tech you're talking with for almost immediate help.
Old 09-02-2014, 01:33 AM
1HGEJ2's Avatar
hello
ive email them on sunday. i hope to get an answer this week
Old 09-03-2014, 09:59 AM
1HGEJ2's Avatar
ive got an answer.
they changed the design. i should machine them to the same spec. but i´ll buy 2 new rods.
Old 09-03-2014, 10:35 AM
Moderator in Chief
Muckman's Avatar
Sounds like you already found your answer. My Pauter rods are from June 2004. Not surprised they changed the design since then. Interesting note: Ive had one rod replaced in 2011. As long as you have the tag that comes with the rods they can make a single rod to the same specs and design. Looks identical to my original rods.
Old 09-03-2014, 07:16 PM
1HGEJ2's Avatar
Wow thats an interesting note.
Old 10-24-2014, 06:14 AM
1HGEJ2's Avatar
update
ive sent pauter my 2 rods. after 2 weeks i pay for 2 rods more.
after 3 weeks ive got 4 brand new identically pauter rods. really really good seller / brand
Old 10-25-2014, 01:23 PM
chickenbandit's Avatar
Nice!!
Old 10-26-2014, 04:51 PM
Moderator in Chief
Muckman's Avatar
So what are you doing with the other 2 mis-matched rods? Couldn't you had them balanced?
Old 10-27-2014, 01:34 PM
1HGEJ2's Avatar
im selling it cheap
https://honda-tech.com/classifieds-f...ds-2x-3227487/
Professor X
08-10-2012 11:22 AM
kte324
10-28-2010 08:38 AM
delsol vti
06-19-2008 03:18 PM
done
11-06-2004 06:01 PM
garados
01-20-2004 05:33 PM
Quick Reply: Big Pauter Rod Problem
