precision 6262 vs 6266?
Old 07-22-2014, 11:43 PM
young geezer's Avatar
Default precision 6262 vs 6266?
so i am stuck on which turbo to go with. my goal is around 550-600 whp. the block is fully build and head is semi built. I am also running on e85. Also i am thinking if i go with 6266, i ll get 63 A/R and if i go with 6262, ill get 82 A/R for faster spooling purpose. What you guys think? thanks in advance.
Old 07-23-2014, 03:51 AM
$MIKE$'s Avatar
Default Re: precision 6262 vs 6266?
What's displacement on the motor?
Cams you will be running and turbo manifold?
Pick a turbo that will make sense with your set up.
Old 07-23-2014, 04:23 AM
luck4rmkc's Avatar
For that power goal just go with the 6262
Old 07-23-2014, 04:29 AM
Turbo-LS's Avatar
5858 with a .82 housing will reach your power goals and have a better powerband if you don't want to go for more power in the future. The 6266 makes 75-100 more hp than the 6262 and the larger exhaust wheel will max out the compressor at lower boost pressures
Old 07-23-2014, 04:54 AM
D-Rob's Avatar
Right, the 5858 will do a killer job at that power level!
Old 07-23-2014, 09:45 AM
2.0L,stock b16 cams and ram horn manifold. i was thinking 5858 but i know i will want more power later on so i think i am leaning more towards 6262. thanks guys.
Old 07-23-2014, 05:58 PM
gringotegra's Avatar
I can tell you based on my recent dyno testing.
An old school 6262 spools every so slightly slower than a 6466! So yes a 900whp turbo spools just as quick as a 750whp turbo lol.
Old 07-23-2014, 06:55 PM
i went with 5858 BB .82 A/R hoping to get 550whp.
Old 07-24-2014, 01:53 AM
Hyper16-Johnny's Avatar
With the elevation you have in CO, I think the 6266 would've been the better choice. Also a major set back you will have will be your cams.
Old 07-25-2014, 09:55 AM
shawty22's Avatar
I had the 5858 JB on my 84mm GSR a couple years ago. Made 560/405 at 20psi. Turbo had more in it, just ran out of fuel. You won't regret your choice, its an awesome street turbo.
Old 07-25-2014, 03:10 PM
Yes it's an awesome turbo, we all know this to be true, but is it enough to make 550-600hp in Colorado's elevation? OP is also utilizing B16 cams for his setup, which is really gonna hold him back. Based off of elevation and cams, a bigger turbo would've been a better choice by keeping it more in it's efficient range, as opposed to running a smaller turbo and throwing massive amounts of boost at it to get to the targeted power range while the efficiency range is out the window.
Old 07-27-2014, 11:15 PM
bigislandc2's Avatar
I just ordered a 6266
Old 07-27-2014, 11:40 PM
extremeracer's Avatar
Is there any data on how much turbo "airflow" you loose with elevation, I'm at a very similar elevation to Denver, CO and have often wondered how this impacts maximum turbo flow capability.
Old 07-28-2014, 12:04 PM
xohcef's Avatar
No cfm loss chart here, but Colorados air sucks. Even though we're at 5800 feet at the track the density altitude always puts us a lot closer to 10,000 feet on race day, especially in June/July/August. If you're in CO try not to tax a weak bearing turbo, or at least get a ball bearing unit if you're going to be spinning a small guy that hard
TeranceFL
05-04-2013 09:42 PM
string
09-12-2006 04:04 PM
EJ8 GSR-T
02-17-2006 11:09 AM
mrbsponge
04-12-2005 06:46 AM
boosted hybrid
11-26-2002 03:16 PM
Quick Reply: precision 6262 vs 6266?
