HELP ME INSTALLING VIPER 5704V REMOTE STARTER IN MY 2006 Honda Element EX 4WD ManlTr
Old 02-07-2014, 11:25 PM
prabhakarglv's Avatar
Icon6 HELP ME INSTALLING VIPER 5704V REMOTE STARTER IN MY 2006 Honda Element EX 4WD ManlTr
Hi,
I'm happy and proud to be a member in this forum. I'm installing VIPER 5704V Remote Starter and Omega OL-AL(MDB)-HA1-EN Bypass module in my 2006 Honda Element EX Sports 4WD Manual Transmission. I'm having experience installing remote starter in 3 cars with automatic transmission. This is the first time I'm installing the remote starter in my Manual transmission vehicle. Please help me whether the wiring connections are correct or not and also help me to find the wires from viper starter to my vehicle which I have not figured still. I would appreciate if you can give me the answer opposite to each wiring question I requested, so that way I can understand easily and take the print-out. The information enclosed below.
MAIN HARNESS, 6-PIN Connector
H1/1 Red (+) 12VDC Constant Input -> White(+) 12 Volts @ Ignition Harness
H1/2 Black (-) Chassis Ground -> goes to Ground
H1/3 Brown (+) Siren Output -> WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H1/4 White/Brown Parking light isolation wire -> WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H1/5 White Parking light output -> (+) Red/Yellow @ Fuse Box Top Green connector (set the fuse to + in the alarm's brain)
H1/6 Orange (-) Ground when armed -> NEED NOT TO USE, am I right?
DOOR LOCK 3-Pin Connector
1. Blue (-) 500mA Unlock Output -> White/Green (-) @ Driver Kick Panel to Grey connector OR ??? right behind it on the left side of the steering column next to a wide brown harness (Black?White Colour)
3. Green (-) 500mA Lock Output -> White/Blue (-) @ Driver Kick Panel to Grey connector OR ??? right behind it on the left side of the steering column next to a wide brown harness (Orange Colour)
REMOTE START, (+) 10-Pin heavy gauge connector @ Ignition Switch Harness
H3/1 Pink Ignition 1 Input/Output -> Black/Yellow @ Ignition harness
H3/2 Red/White Fused (30A) Ignition 2 / Flex relay input 87 -> White(+) 12 Volts @ Ignition Harness
H3/3 Orange Accessory Output -> Black/Red Accessory wire @ Ignition Harness
H3/4 Violet Starter Output (Car side of the starter kill) -> Cut Black/White Starter wire and connect on the car side of the starter kill
H3/5 Green Starter Input (Key side of the starter kill) -> Already cut Black/White connect on the key side of the starter kill
H3/6 Red Fused (30A) Ignition 1 Input -> Is this should connect to Black/Yellow of Ignition OR White(+) 12 Volts @ Ignition Harness?
H3/7 Pink/White Ignition 2 / Flex Relay Output -> WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H3/8 Pink/Black [/b]Flex Relay Input 87A key side (if required) of Flex Relay -> NEED NOT TO USE, am I right?
H3/9 Red/Black Fuse (30A) Accessory/Starter Input -> White(+) 12 Volts @ Ignition Harness
AUXILLARY/SHUTDOWN/TRIGGER HARNESS, 24-Pin Connector
H2/1 Pink/White (-)200mA Ignition / Flex Relay control output -> WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/2 Black/White (-) Neutral Safety Input ->Goes to Green/Orange wire of Parking/Emergency Brake @ Under Dash Fuse Box Top Right Green connector
H2/3 Blue/White (-)200mA 2nd Status / Rear Defogger Output ->NEED NOT TO USE, am I right? OR Should connect to Yellow/Black Rear Defrost wire located behind Radio?
H2/4 Green/Black (-)200mA OEM Alarm Disarm Output -> NEED NOT TO USE, am I right? OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/5 Red/White (-)200mA Trunk Release Output -> Should connect to Black/Yellow @ Driver Kick Panel to Grey Connector OR NEED NOT TO USE, am I right?
H2/6 Green (-) Door Trigger Input -> WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/7 Black/Yellow (-)200mA Dome light supervision -> Green/Red (-) @ Under Dash Fuse Box OR NEED NOT TO USE, am I right?
H2/8 Brown/Black (-)200mA Horn Honk Output -> Orange (-) @ Steering Column OR NEED NOT TO USE, am I right?
H2/9 Dark Blue (-)200mA Status Output -> GWR Wire of Bypass Module (Omega OL-AL) OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/10 Pink (-)200mA Ignition 1 Output - > WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/11 White/Black (-)200mA AUX 3 Output -> NEED NOT TO USE, am I right? OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/12 Violet (+) Door Trigger input -> NEED NOT TO USE, am I right? OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/13 White/Violet Aux 1 Output -> NEED NOT USE, am I right? OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/14 Violet/Black Aux 2 Output -> NEED NOT TO USE, am I right? OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/15 Orang/Black Aux 4 Output -> NEED NOT TO USE, am I right? OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/16 Brown (+) Brake Shutdown Input -> White/Black @ Brake Switch Harness OR NEED NOT TO USE, am I right? OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/17 Grey (-) Hood Pin Input -> Connect to wire from the hood pin
H2/18 Violet/Yellow (-)200mA Starter Output -> WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/19 Blue (-) Trunk Pin/ Instant trigger input -> NEED NOT TO USE, am I right?
H2/20 Grey/Black (-) Diesel Wait to start -> N/A
H2/21 White/Blue (-) Remote start/ Turbo timer activation input -> NEED NOT TO USE, am I right?
H2/22 Orange (-) 200mA Accessory Output -> NEED NOT TO USE, am I right? OR WHAT WIRE TO CONNECT AND WHERE IS THE LOCATION OF THE WIRE ?
H2/23 Violet/White Tachometer input -> Blue (~) wire at ECM Module behind Glove Box (IS THERE ANY BEST LOCATION TO ACCESS THIS WIRE???)
H2/24 Green White (-) 200mA OEM Alarm Arm Output -> N/A
YOUR HELP IS MUCH APPRECIATED FOR MY PAPER WORK BEFORE INSTALLATION IN MY CAR. THANK YOU.
REGARDS,
PUBBY.
Old 02-15-2014, 02:18 PM
Icon2 Re: HELP ME INSTALLING VIPER 5704V REMOTE STARTER IN MY 2006 Honda Element EX 4WD Man
Hi,
I connected almost all the wires except few. I also have few more questions before I complete this project,
The 1st question is, For H2/18 Violet/Yellow (-)200mA Starter Output -> what I heard for the Manual transmission vehicles this wire should connect to the CLUTCH WIRE, am I right?. There are TWO CLUTCH PLUGS in my vehicle, one is YELLOW COLOUR PLUG and the other one is WHITE COLOUR PLUG. When I went through Google search engine some said it should connect to Blue/White wire of Yellow plug Connector to see ground during Crank. My question is need I have to use any Relays or Diodes for this Starter output wire or don't need to use anything other than direct connection of wires. But if I need to use Diode, what is the specification of Diode I need to use?
The 2nd question is,FOR H3/6 Red Fused (30A) Ignition 1 Input -> Is this wire should connect to Black/Yellow of Ignition OR
The 3rd Question is, H2/6 Green (-Ve) Door Trigger Input -> When I went through Google search engine some said it should connect to Green wire (Driver's Door) and Grey/Black (Passenger's Door) @ Steering Column Harness. But they mention to use the Diode. How should I connect the Diode to these wires and what type and specifications of Diode I need?
I would appreciate your reply.
Thank you,
Pubby.
Old 02-16-2014, 08:19 PM
k_than's Avatar
Default Re: HELP ME INSTALLING VIPER 5704V REMOTE STARTER IN MY 2006 Honda Element EX 4WD Man
Originally Posted by prabhakarglv
Hi,
It should be blue wire status output that will senf a ground signal only when remote start is activated, im not sure which wire it is for you car but it needs to be connected to the ground wire of the clutch pedal switch or at the start cut relay.
12v at ignition harness it is fused.
You can use 1amp diodes which can be purchased at radio shack 1 diode for each door trigger wire connect the diode to door trigger wire with the line on the diode to the door trigger side and the other end of the diode to green wire on alarm.
Thank you,
Pubby.
Mars401
11-14-2016 02:16 PM
prabhakarglv
Honda CR-V & Element
02-17-2014 03:56 PM
lmrbtj
06-10-2008 10:28 PM
Morning Call
12-18-2004 01:42 PM
bushfreakz
01-17-2004 06:24 PM
Quick Reply: HELP ME INSTALLING VIPER 5704V REMOTE STARTER IN MY 2006 Honda Element EX 4WD ManlTr
