2000 civic fuel pressure regulator help
My 2000 civic b18c1 starting sputtering at stops a while back, I went and got a used fuel pressure regulator at the junk yard and switched it with the one I had on. It ran good for about 2-3 weeks with no problems what so ever and no sputtering idling around 1k. 2 days ago it started doing it again, even worse then before, like it's not getting enough gas, I'm thinking about buying a new one but want to know if I should just get a stock fuel pressure regulator or a different one, there are pricey and I want to get the best for my car.
Re: 2000 civic fuel pressure regulator help
Ok I will look into a new fuel pump, so do you think my regulator is not the problem then since I kinda changed it and the symptoms went away?
I changed my fuel liter last month before I changed my regulator. I changed spark plugs in June.thats about it, no cel as of right now, the last cel that came up was about 2 months ago for a knock sensor but I changed that already
I will check my spark plugs again to see if they look bad, and how do I check my fuel pressure to see if the gas flows evenly in my car I read somewhere about that on hondatech but I am not to sure on how or where to start on that
skUnK2jdm
01-30-2007 03:55 PM
iNetForce
11-13-2005 08:27 PM
hybridtech
04-17-2005 03:44 PM
