1992 Civic VX won't crank
Old 03-21-2013, 05:03 AM
TerminatioN's Avatar
Default 1992 Civic VX won't crank
Hi guys,
My 1992 Civic VX won't crank.
It is almost completely stock, except for a few minor modifications that are mostly unrelated.
Anyways, basically the problem is that the car won't crank it all. Turn the key and nothing. The starter doesn't even try...
-The battery is fairly new and I checked the voltage with a multimeter, and it is providing the proper voltage.
-I checked the power wire to the starter with a multimeter, and it had good continuity.
-I ran a direct hot line to the starter, and it still did nothing...
-The clutch interlock switch is bypassed, so that is not the issue.
-I have push started it several times, and it runs fine after that.
Now for the weird part... when I hold the key to the start position, and have someone wiggle wires randomly down near the starter, the starter will randomly spring to life sometimes, and when it does, the car starts up fine and runs fine, but will not start back up after that.
Initially I thought it was the starter, but now I am not so sure... any ideas?
Old 03-21-2013, 05:11 AM
The Grumpiest
grumblemarc's Avatar
Default Re: 1992 Civic VX won't crank
Starter. Have it tested.
Old 03-21-2013, 05:29 AM
92 civic ex 4dr's Avatar
Agree. Also test/check/clean your grounds. I had a problem just like that. Turns out that the stock anti theft system (which want hooked up to power but still the vehicle) had ended up grounding out on the firewall causing a short. When it shorted out the starter immobilizer was activated.
I removed the dash and any and all wiring having anything to do with it and she has ran/started **** every time.
Posted from Honda-tech.com App for Android
nestea8869
10
03-26-2022 10:12 AM
JJT211
06-22-2014 08:33 PM
brandejo
09-22-2013 03:41 PM
dirtygerman
06-17-2011 07:04 PM
PePe240sx
06-07-2011 01:37 PM
Quick Reply: 1992 Civic VX won't crank
