Dome light won't come on as doors are opened
Old 02-17-2013, 08:39 AM
Blazing angel's Avatar
Default Dome light won't come on as doors are opened
Heres my situation.
1999 Honda Civic Special Edition Canadian Model
Driver door: Harness completely dead. Mo wires going into doors.
Passenger Door: Speakers work, keyless entry wire are broken.
Keyless entry doesn't work at all.
The Dome light: works when switch is in the "on" position. I believe the car chimes when the door is open and the key is still in the ignition.
Since so many wires are ruined, and keyless is dead, am I SOL when it comes to the dome light coming on with the doors?
Old 02-17-2013, 08:44 AM
gsrekcoupe's Avatar
Default Re: Dome light won't come on as doors are opened
There is three setings on your dome light the on position the middle position is where the light comes on when the doors are opened and the of position, so just set it in the middle position and your set, mine is a 98 Canadian model to
Old 02-17-2013, 09:32 AM
That Doesn't work. I should clarifiy
Off-off
on-light turns on
Door- light should turn on with open doors, but doesn't turn on when doors open.
Old 02-17-2013, 09:36 AM
Former User's Avatar
I'm confused. You seem to know that there are bad wires. Why don't you just fix or replace them?
Old 02-17-2013, 09:41 AM
HOMEMADEPOWER's Avatar
Did you check the fuse?
Old 02-17-2013, 09:50 AM
Alright Sorry for the lack of information. Due to a very (very) stupid reason, There is no harness going to my car driver door. Just a bunch of cables tied up in the driver door jamb. (very annoying. Don't even have a driver door speaker). I was wondering if the door harness is linked to the dome light. If it is, then I can't really fix it (as of right now, without a new harness.)
Old 02-17-2013, 05:18 PM
Old 02-18-2013, 03:27 PM
Does anybody know if the dome light is linked to the doors or the little buttons underneath the doors?
Old 02-18-2013, 03:39 PM
The dome light door switch is not in the door itself and doesn't have any wires there. It's in the door jam.
Old 02-18-2013, 03:49 PM
chasingadrenali's Avatar
^^x2 the switch that tells the car that the drivers side door is opened is in the door jamb itself, the wire for it runs behind the plastic panel thats behind the drivers seatbelt, runs down the running boards (plastic piece that is on the bottom of the door jamb), then runs up under the dash to the rest of the wiring harness. so essentially, it has nothing to do with the wires that run in to the drivers side door, but id suggest that you fix those wires.
hon0405
12-07-2016 01:29 PM
John Anderson
13
03-30-2012 06:44 PM
Aftermath_Hatch
12-02-2009 01:59 PM
zsudz922
Audio / Security / Video
10-01-2009 02:21 PM
Quick Reply: Dome light won't come on as doors are opened
