2003 Accord window issue
Hello,
I have a 2003 Honda Accord coupe. I recently replaced the driver's side window motor and regulator because the window would not operate. The window now works but when the window is in the full up position, I now hear what sounds like the window engaging trying to make itself go up (a little ping of sort.) What would cause this and how could this be fixed?
I tried to reset the master mindow switch but it did not seem to stop the noise. I also tried to search the forums and I see some posts related to window problems but none adressing this specific question. Sorry if redundant.
Dave
Dave
Re: 2003 Accord window issue
Try removing both battery cables (making sure you have your radio code handy after you install the cables) and touching them togther for about 5 minutes. Keep in mind that you're not touching the battery posts together, just the cables. A jumper wire is best used for this purpose. This will drain any residual power retained by electrical components--a resetting of sorts. In weird circumstances like that it's always the first thing I will do before any other electrical troubleshooting. Let me know how that works.
Well, I tried your suggestion and I think it worked. I removed both cables from the battery and hooked up a jumper wire and connected them together. I waited 20 minutes and then re-installed the cables to the battery. The noise seems to of gone away. Thank you for your suggestion!
Hello Justin.
I have a similar problem as Dave.
I just bought an 03 accord coupe 3 days ago, and i parked it in walmart at the very far end. After shopping, i see my windows are lowered a few inches. I thought someone broke in using suction cups or something. But everything was still in place. Then now i noticed that my window motors are starting to give up. Its like the windows are too heavy on them. And i can literally grab the windows on both ends and move them couple of inches up or down. Is that normal? I mean i dont want my vehicle to be easy to break in. Is there something i should worry about?
Hope to hear from you soon.
Thanks Justin
Thanks Justin
Hello Justin.
Thanks Justin
Thanks Justin
flam2828
07-02-2019 03:34 AM
Bj Reynolds
10-30-2015 01:37 AM
Dev1996
10-20-2015 06:28 AM
