2003 Accord window issue - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 10-12-2011, 04:02 PM   #1
Default 2003 Accord window issue
Hello,
I have a 2003 Honda Accord coupe. I recently replaced the driver's side window motor and regulator because the window would not operate. The window now works but when the window is in the full up position, I now hear what sounds like the window engaging trying to make itself go up (a little ping of sort.) What would cause this and how could this be fixed?
I tried to reset the master mindow switch but it did not seem to stop the noise. I also tried to search the forums and I see some posts related to window problems but none adressing this specific question. Sorry if redundant.
Dave
dave_fitz is offline   Reply With Quote
Old 10-14-2011, 04:19 AM   #2
Default Re: 2003 Accord window issue
Try removing both battery cables (making sure you have your radio code handy after you install the cables) and touching them togther for about 5 minutes. Keep in mind that you're not touching the battery posts together, just the cables. A jumper wire is best used for this purpose. This will drain any residual power retained by electrical components--a resetting of sorts. In weird circumstances like that it's always the first thing I will do before any other electrical troubleshooting. Let me know how that works.
justinsbg is offline   Reply With Quote
Old 10-16-2011, 04:53 PM   #3
Well, I tried your suggestion and I think it worked. I removed both cables from the battery and hooked up a jumper wire and connected them together. I waited 20 minutes and then re-installed the cables to the battery. The noise seems to of gone away. Thank you for your suggestion!
Old 10-17-2011, 12:01 PM   #4
Quote:
Glad I could help.
Old 04-08-2012, 08:21 PM   #5
Hello Justin.
I have a similar problem as Dave.
I just bought an 03 accord coupe 3 days ago, and i parked it in walmart at the very far end. After shopping, i see my windows are lowered a few inches. I thought someone broke in using suction cups or something. But everything was still in place. Then now i noticed that my window motors are starting to give up. Its like the windows are too heavy on them. And i can literally grab the windows on both ends and move them couple of inches up or down. Is that normal? I mean i dont want my vehicle to be easy to break in. Is there something i should worry about?
Hope to hear from you soon.
Thanks Justin
slalwani88 is offline   Reply With Quote
Old 04-15-2012, 06:28 AM   #6
Quote:
Originally Posted by slalwani88 View Post
Hello Justin.
Thanks Justin
The alarm on my 03 V6 sedan lowers all the windows when I press the button again. Are you sure you didn't just happen to do this then forced the window up and down causing the problem? Just suggesting as it is sometimes done by those who don't know the alarm lowers the windows too.
gstephen70 is offline   Reply With Quote
Passenger Window Issue fharris1977 Honda Accord & Crosstour (2003 - 2012) 1 07-11-2015 12:50 PM
2005 Honda Accord Coupe Power Window dandyjefe Honda Accord & Crosstour (2003 - 2012) 0 02-24-2014 11:57 AM
91 accord SE auto 2.2L Need Help with driver's side Window davidcrevenston Honda Accord (1990 - 2002) 22 10-06-2010 09:02 PM
Window regulator tx95excoupe Honda Civic / Del Sol (1992 - 2000) 11 09-14-2007 05:43 AM
Slow Window Problem Solution MESSED UP MY WINDOWS ! xunkn0vvnx Honda Accord (1990 - 2002) 1 08-30-2002 04:27 AM
Tags
03, 2003, accord, drivers, electrical, honda, pilot, powered, products, regional, regulator, sales, specialist, vbulletin, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
