2006 Accord Window Problems.
I have a 2006 Accord and I am having problems with my power windows. More specifically, my passenger and rear windows will not roll down. The driver's side window is the only one that works. The windows will not work from the main controls at the driver's side or from any of the controls from each window. I have checked the safety lock, it is off. The fuses appear to be fine as well. When I try and roll the windows down, I can hear a faint clicking sound from each window as I try them.
Is there anything I can try to do to reset/fix this? I want to try everything possible before taking it to be looked at since the car is no longer under warranty (47,000+ miles). Thanks for any help!
Re: 2006 Accord Window Problems. (xkrakenx)
It sounds like the regulator or motor. I dont know about the 06, but in previous years they sold the motor and regulator together which made for easier installation.
I AM A SERVICE ADVISOR AT MCDAVID IN IRVING TEXAS, THOSE REGULATORS
ARE UNDER WARRANTY FOR BEING TO NOISY.... TAKE TO THE DEALER FOR THE RESOLUTION TO YOUR PROBLEM
Re: 2006 Accord Window Problems. (kurvy)
noisy regulators still work.
most likely the problem is the driver master window switch. i've done a fair amount of driver master switchs but only a handful of regulators that are completely dead(not just noisy)
Re: 2006 Accord Window Problems. (HondaTechAV6)
Thanks for the replies guys. I guess I will run it by a dealership. The funny thing is, since I posted the windows have been working off and on. Which leads me to believe there is a short at the main switch where the window lock button is. Maybe some rain water could have caused it, not sure.
Anyway, thanks again!
I just replaced my driver master switch in my '04 Accord. However, I have no power windows or locks now. I also cannot use my remote....From looking around at different forums it looks like I need to reset my master switch before it will work, but I'm not sure how to do that. I found instructions to fix the "auto" down and up features, but I can't use those instructions because they assume that the window is at least going up and down by holding the switch in the up or down position.
Any help on how to reset the driver master switch?? I am pretty confident that my new switch is not defective....it was working in the car it was pulled out of.
brandon123789
07-23-2019 08:03 PM
