Honda Accord Window Won't wind up
Hi folks,
I have a Honda Accord 2005 VTi.
This week I was winding down the drivers window and when I tried to wind it up it would go up a little but then return to fully open. It wouldn't go back up, winding back up to about 1/4 way before winding down. The motor is engaged when rising and lowering.
I have another Honda Accord same model but 2004. I swapped out the switch unit on the drivers door, the problem was still there.
If I grab the window and force it up past (or around) the half way mark, while keeping my finger on the window switch (to close) so as to wind the window up, the window will close.
If I wind the window down no more than (approximately) 3/4 way down, and stop winding the window down, it will remain in position and when I try to close the window, the window will return to the closed position without a problem.
The swapping of the switch was a quick fix, but does anybody have a notion what might be goings on?
Thanks
Flam2828
Thanks
Flam2828
