Accord 2007 lock button remote key malfunction - Help.
Old 08-08-2011, 10:02 AM
grandm's Avatar
Default Accord 2007 lock button remote key malfunction - Help.
^. Anyone have any ideas what might be to problem? It was working perfectly fine the a few days ago and now only the lock button on the remote key is not working.
The battery should not be the problem since the red light blinks fine when I press the lock button and I can lock the door just fine manually (by pushing down the, using the master switch next to the window switch or inserting my car key - The driver side central locking switch is working fine). I also had a spare remote key that I had not used in years but the same problem still persists.
I called the honda dealer to see if he might be able to help but he said he has no idea and I could have the car go on a diagnosis for $98 (not including getting it fixed). I have a feeling it is just a minor problem and would be glad if I can save that money instead. Thanks for your time and input.
Old 08-08-2011, 11:32 PM
Kev2010's Avatar
Default Re: Accord 2007 lock button remote key malfunction - Help.
Best option is just to go to the dealer.
This doesn't sound easy to diagnose.
Old 08-10-2011, 10:53 AM
kytydenmal's Avatar
Oh my gosh, I have the same problem. I have a 2007 Honda Accord and my lock button on the key does not work. It hasn't worked in a few weeks now and I just decided to search online to find out what the problem is. The other buttons work but when I go to use the lock button, the doors lock but NOT the driver side door. I have to manually push the driver side door lock down and then I activate the alarm.
Grandm, have you found out what the problem is yet? I don't want to go to the dealer either.
Thank you.
Elvis1977
10-29-2018 10:08 AM
pdelo
04-30-2015 12:34 PM
tshannoz
14
08-22-2012 11:28 PM
ronaldbmm
05-21-2012 08:26 PM
joysarkar
08-20-2010 07:15 PM
Quick Reply: Accord 2007 lock button remote key malfunction - Help.
