Accord 2007 lock button remote key malfunction - Help. - Honda-Tech - Honda Forum Discussion
Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 USA Accord and Inspire
Old 08-08-2011, 10:02 AM   #1
Default Accord 2007 lock button remote key malfunction - Help.
^. Anyone have any ideas what might be to problem? It was working perfectly fine the a few days ago and now only the lock button on the remote key is not working.
The battery should not be the problem since the red light blinks fine when I press the lock button and I can lock the door just fine manually (by pushing down the, using the master switch next to the window switch or inserting my car key - The driver side central locking switch is working fine). I also had a spare remote key that I had not used in years but the same problem still persists.
I called the honda dealer to see if he might be able to help but he said he has no idea and I could have the car go on a diagnosis for $98 (not including getting it fixed). I have a feeling it is just a minor problem and would be glad if I can save that money instead. Thanks for your time and input.
grandm is offline   Reply With Quote
Old 08-08-2011, 11:32 PM   #2
Kev2010's Avatar
Default Re: Accord 2007 lock button remote key malfunction - Help.
Best option is just to go to the dealer.
This doesn't sound easy to diagnose.
Kev2010 is offline   Reply With Quote
Old 08-10-2011, 10:53 AM   #3
Oh my gosh, I have the same problem. I have a 2007 Honda Accord and my lock button on the key does not work. It hasn't worked in a few weeks now and I just decided to search online to find out what the problem is. The other buttons work but when I go to use the lock button, the doors lock but NOT the driver side door. I have to manually push the driver side door lock down and then I activate the alarm.
Grandm, have you found out what the problem is yet? I don't want to go to the dealer either.
Thank you.
kytydenmal is offline   Reply With Quote
Instructions to program a keyless remote for a 1998 Honda Accord. jca1972 Honda Accord (1990 - 2002) 3 02-06-2017 01:56 PM
All Power Door locks not working with the remote key shiru Honda Element & CR-V 1 10-22-2016 01:56 PM
Doors cannot lock from the master switch or remote key XIV Honda Accord & Crosstour (2003 - 2012) 25 08-07-2014 06:51 PM
Drivers door lock problems jessa024 Honda Accord & Crosstour (2003 - 2012) 3 07-14-2011 03:02 PM
Problem With Keyless Entry and Driver Door xtreme 2 Acura TSX 2 03-23-2008 08:49 PM
Tags
2003, 2007, 2008, accord, button, car, honda, key, lock, locking, problems, properly, remote, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
