DIY: How to replace rear wheel bearing (drum brakes)
Old 10-21-2011, 06:28 AM
  #26
Seagull Management
94EG8's Avatar
Default Re: DIY: How to replace rear wheel bearing (drum brakes)
Originally Posted by EscoSi
do you know if the bearing is the same for both drums and disc at the rear?
They aren't. One sticks out a little further than the other, I can't remember which is shorter than the other.
Old 10-21-2011, 07:24 AM
  #27
#1 Super Guy
94eg!'s Avatar
Here is my DIY for changing front bearings with a Harbor Freight Tool Set ($90). It's worth it if you love tools and are a hard-core DIY'er... lol
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/front-wheel-bearing-replacement-harbor-freight-tool-set-66829-a-2984426/
Old 10-21-2011, 07:27 AM
  #28
#1 Super Guy
94eg!'s Avatar
The main difference is the bearing inner diameters.
Here is a list of part numbers for different rear hubs that I made when helping out another HT member:
NTN Part numbers & Interchange Part#’s
Rear:
- HUB008-72 = 513035 = BR930033 = EF/EG/EK NON-ABS rear drum hub/bearing
- HUB005-65 = 512034 = BR930127 = EG/EK/DC NON-ABS rear disc hub/bearing
- HUB005-36 = 513033 = BR930010 = EF/DA NON-ABS rear disc hub/bearing
- HUB005-37 = 513105 = BR930113 = EG/DC ABS rear-disc hub/bearing (not Type R)
- HUB008-71 = BR930480 = EK ABS rear-drum hub/bearing
- HUB186-6 = = DC2/EK9 Type R 5x114.3 w/ ABS
Front:
- AU0907-7LXLL588 = 510030 = EG/DC/EK 10.4” & Type R front-disc wheel bearing
- AU0811-6LXLL588 = 510015 = EG/EK 9.5” front-disc wheel bearing
- DE0829LLCS32PX15A = 513241 = DA 10.4” front-disc wheel bearing
- DAC3872W-10CS42 (KOYO) = 513024 = EF 9.5” front-disc wheel bearing
Hands down best prices for OEM/NTN bearings are at FindItParts.com. Not only are they the lowest, but you can find coupon codes for extra 10% off that helps cover postage. Current code is 2ap311 last time I checked.
Old 10-21-2011, 10:50 AM
  #29
project93hatch's Avatar
nice write up.
Old 10-21-2011, 03:46 PM
  #30
h1ghsp3ed's Avatar
agreed nice write up
Old 10-21-2011, 06:26 PM
  #31
dele22's Avatar
Just wanted to thank you OP, have to replace mine as soon as the next rainless day hits. Also, for what it's worth, here's some relevant info on the rear wheel bearings:
Originally Posted by dele22
Did a little bit of leg work and found out that Timken makes the OEM hub/bearing assy, which uses the NTN bearing. The Timken part number is 513035 and they can be had for $40-50 after shipping on most auto parts websites.
Compatibility chart:
1998-2000: GX; All Engines;
1996-2000: HX; All Engines;
1990-2000: EX; All Engines;
1989-2000: CX; All Engines;
1988-2000: LX; All Engines;
1986-2000: Si; All Engines;
1985-2000: DX; All Engines;
1999-1999: Value Package; All Engines;
1992-1995: VX; All Engines;
1985-1991: Base; All Engines;
1988-1989: Wagovan; All Engines;
1988-1988: SE; All Engines;
1985-1987: 1500 S; All Engines;
1985-1987: CRX HF; All Engines;
1985-1987: CRX Si; All Engines;
1985-1987: CRX; All Engines;
And the charts for the aftermarket eBay bearings ($30) which match the specs of the Timken
ACURA EL (1997 - 2000)
HONDA CIVIC (1985 - 1991)
HONDA CIVIC 1300 1987
HONDA CIVIC 1500 (1985 - 1987)
HONDA CIVIC 1500 DX (1985 - 1988)
HONDA CIVIC 1500 S (1985 - 1987)
HONDA CIVIC 1500 SI (1986 - 1987)
HONDA CIVIC CX (1989 - 2000)
HONDA CIVIC DX (1985 - 2000)
HONDA CIVIC EX (1990 - 2000)
HONDA CIVIC GL 1986
HONDA CIVIC GX (1998 - 2000)
HONDA CIVIC HX (1996 - 2000)
HONDA CIVIC LX (1988 - 2000)
HONDA CIVIC SE 1988
HONDA CIVIC SI (1989 - 2000)
HONDA CIVIC VALUE PACKAGE 1999
HONDA CIVIC VX (1992 - 1995)
HONDA CIVIC CRX (1985 - 1987)
HONDA CIVIC CRX HF (1985 - 1987)
HONDA CIVIC CRX SI (1985 - 1987)
HONDA CRX 1991
HONDA CRX 1500 HF (1988 - 1989)
HONDA CRX DX (1988 - 1990)
HONDA CRX HF (1990 - 1991)
HONDA CRX SI (1988 - 1991)
HONDA CIVIC DEL SOL S (1993 - 1997)
HONDA CIVIC DEL SOL SI (1993 - 1997)
HONDA CIVIC DEL SOL VTEC (1994 - 1997)
HONDA WAGOVAN (1986 - 1987)
Originally Posted by 94eg!
FYI: Then HUB008-72 is the right hub for you. Additional part number shown is 513035. Finditparts has cheap shipping ($6 for 2 hubs to NV) and a 15% off coupon you can use in the later stages of checkout "2ap311" that worked as of Monday. I don't think you can find a better price on NTN hubs.
http://www.finditparts.com/products/.../ntn-hub008-72
BTW: I don't think Timken actually makes anything. They just buy and repackage. Their front Integra wheel bearings are made by F.A.G. instead of NTN or Koyo.
***edit: Here's what I found about part numbers:
NTN Part numbers:
You can buy the non-abs hub and transfer the ABS ring from your old hub to save some money.
I got my bearing assemblies from Rockauto.com for $30 each
Old 10-21-2011, 08:54 PM
  #32
#1 Super Guy
94eg!'s Avatar
If they were NTN, then I would be excited. :D
Old 01-17-2012, 02:24 PM
  #33
BrowNKiD's Avatar
I have done a lot of searching. But I can not find the information I need. I have a 92 civic si rear disk NON ABS... which ABS hub can I use?
Old 01-17-2012, 04:39 PM
  #34
Resident Gearhead
BryanM.'s Avatar
The car doesn't have ABS but you want to use ABS hubs for the rear?
Old 01-17-2012, 04:53 PM
  #35
BrowNKiD's Avatar
Yes... I know weird right. I am going to be using the abs ring as a speed sensor. BUT I need to find an ABS hub that will fit my 92 si rear disk spindle.
Old 01-17-2012, 05:00 PM
  #36
sde780's Avatar
When I bought wheel bearings they had ABS and non-ABS versions available at Advance Auto Parts. The non-ABS was cheaper and I re-used my ABS ring.
Old 01-18-2012, 01:57 PM
  #37
BrowNKiD's Avatar
I bought 513105 but the spindle diameter is too large...
Old 01-18-2012, 02:35 PM
  #38
sde780's Avatar
Slide your new bearing on to check fit. MINE WAS THE WRONG ONE, EVEN THOUGH PART NUMBER WAS CORRECT! It slid on there but the center hole was much too big, it wasn't a snug fit at all. I had to go back and get one without the ABS ring, this one fit perfect. Take a screwdriver/hammer and hammer the old ring off, then center it on the new bearing and use a piece of wood in between to ensure it goes down evenly.
I had that problem initially, it was the ABS version. Got the non-ABS version and it fit great.
Old 05-01-2012, 12:08 PM
  #39
Jaminak's Avatar
Thanks for this great how to, with pictures! I changed the rear hub out today. I also had the inner race stay on the spindle. There is an easier way to get the race off than be removing the backing plate. Just slide your long screwdriver down through the brake cylinder and tap the race a little. Do this on each side. Then grab it with your piers and pull it off. Simple!
Here is my awesome diagram. Red screwdrivers. Green bad inner race.
Old 05-01-2012, 03:22 PM
  #40
Resident Gearhead
BryanM.'s Avatar
That works in a pinch, but you have to pull the wheel cylinder to do that. Or am I misunderstanding?
Instead, if you hit the stuck race with a torch (or maybe even MAP) it should pull off the spindle with pliers.
Old 05-15-2012, 10:32 AM
  #41
Jaminak's Avatar
Nothing extra needed to be pulled. Just slide the screwdriver down between the cylinder and the backing plate.
Davi_Vtec
02-16-2013 08:28 AM
JaguarS4R
Honda Civic (2001 - 2005)
10-21-2010 04:32 AM
Mr.Speed
06-15-2010 03:37 PM
Streetneon2185
06-05-2007 09:39 PM
jason_alt
11-21-2004 10:14 AM
Quick Reply: DIY: How to replace rear wheel bearing (drum brakes)
