Need HELP! B16a2 swap 97 ek idles at 2 grand
i need some help. i just swapped in a b16 into my ek and i cant get the idle to drop under 2 grand. im using a OBD2b to OBD1 convension harness to my chipped obd1 ecu
Re: Need HELP! B16a2 swap 97 ek idles at 2 grand
its not my ecu grumblemarc because it did the same thing with my stock si ecu.
and TTacous yes it is 99-00 harness and engine. but i dont have the dash harness that plugs into the ecu because my shell is a 96-98 ek. could that cause the problem?
well my cel is on but i dont know how to check the codes since i converted it to obd1. and i know im missing a knock sensor. and my throttle body is fine. plenty of slack on the throttle cable
Check codes then come back and tell us whats wrong.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Also you may have to adjust the TPS sensor
http://www.youtube.com/watch?v=ukPoe5E4Fqg
ok guys i went to read the codes but my dam cel doesnt light up! it wont send me any codes. i used the link raidacaipo posted to check the codes but when i use the blue connector nothing happens. i seriously need some help guys
would dat also cause it to run rich? i pulled the spark plugs the other day and they all were covered in crbon dust. they are brand new not even 100 miles on them
im running an obd2 99 civic si harness with obd2 injectors on a obd1 intake mani wit an obd2b to obd1 step down harness without the 99-00 civic obd2 dash harness
^^ if you can't do a simple task of giving us the codes, then there's really no point in helping.. Try and figure out the codes its the easiest thing to do before you do anything else.
Are you doing it correctly? Did you turn the car on the "On" position? are you jumping the correct connector?
egvtec
08-18-2008 08:20 PM
818SpoonITR
09-21-2007 07:18 AM
deluzracerx
06-18-2005 07:51 AM
