What are the symptoms of bent valves?
Old 12-11-2010, 12:59 PM
vtec@4000rpm's Avatar
Default What are the symptoms of bent valves?
i got a 90 DA9 ls with a b16a i may have bended valves but im not sure. if i do the guy before me couldnt put it on gear. so i wanna know wat does a car with bended valves do
Old 12-11-2010, 01:13 PM
H-T Order of Merit
nsxtasy's Avatar
Default Re: What are the symptoms of bent valves?
When you say he couldn't put it in gear, what do you mean? He couldn't move the gearshift from neutral to any of the gears? That sounds like a transmission/clutch problem, not an engine problem like bent valves.
I'm not a technical expert but I had an engine that jumped the timing, and the engine wouldn't run. You could crank it and it would start but it would run VERY rough and you had to keep your foot on the gas to keep the revs way up; the instant you let off the gas or tried to let out the clutch, it would die.
Old 12-11-2010, 01:36 PM
el crapitan's Avatar
bent valves/ skipped timing will cause a loss in compression.
it has nothing to do with the transmission
Old 12-11-2010, 06:36 PM
fv8s's Avatar
Bent** valves. And what do you mean "couldn't put it on gear"?
Old 12-11-2010, 08:14 PM
wunfstgsr's Avatar
ow you will know when you have bent valves, when the car sounds like a suburu then you know.
Old 12-11-2010, 08:29 PM
EHondaJDM's Avatar
Originally Posted by EHondaJDM
OLD SCHOOL TRICK TO CHECK FOR BENT VALVES:
-Get a uncreased piece of white lined paper (Not construction paper or similar its too thick)
-Let your car warm up to operating temp and allow it to idle
-Hold the paper flat over your exhaust so it covers the end completely
-Watch the paper closely, if all is normal it should just keep flapping outward. If you have a bent valve the paper will get sucked into the exhaust before it is pushed out
Only other way I've seen it done without taking the head off is using a fiber cam
Old 12-15-2010, 04:21 PM
verycooljdm's Avatar
They have bent valves on purpose too no?
Old 12-16-2010, 04:34 AM
vrrodri's Avatar
Had the same thing happened to me recently, it jumped timing after an install, not sure how the hell that happened but it ran very rough and required gas to keep it from dying. Luckily it did not bend any valves.
Old 12-16-2010, 05:41 AM
EHondaJDM's Avatar
What are you talking about??
Old 12-16-2010, 07:40 AM
Dynasty21's Avatar
Location: Where We Squeeze 1st N Ask Questions Last, CA, USA
I believe he was referrin to Subi's have bent valves.
Old 12-16-2010, 07:59 AM
EHondaJDM's Avatar
Oh, this guy had me nervous for a min
Old 01-10-2012, 07:42 AM
toby350's Avatar
No hes right if you have a bent valves its gana SOUND like a sti subaru
Old 01-10-2012, 07:44 AM
bryan24207's Avatar
it'll sound like a subaru if its even running, i know on my evo when the shop messed up my car and my valves bent, car wouldnt run
Old 01-10-2012, 08:17 AM
The Grumpiest
grumblemarc's Avatar
Thread resurrection!
Old 01-10-2012, 08:19 AM
bryan24207's Avatar
haha i just noticed the dates on it, guess toby had alot of spare time to do some reading
Old 01-10-2012, 10:02 AM
Hidenplanvew's Avatar
why an sti? Why cant it be like a wrx or a legacy or a forester, or an RS?
Old 01-10-2012, 03:53 PM
vedocustoms128's Avatar
i think subaru sound great.
Old 01-10-2012, 04:53 PM
RookieCivic's Avatar
YES! but when your honda sounds like one you might have some problems
Old 01-10-2012, 10:13 PM
01oemTeggy's Avatar
x2 My integra sounded like a subaru when i had a bent valve. It was cool having all my friends like. "whoa, did you rebuild your teggy with performance parts?" Then i felt stupid and gave them the answer.
Old 01-10-2012, 10:28 PM
DirtyDA9's Avatar
Ahhh I totally forgot about this trick, oldschool stuff right here, one of the first "tricks of the trade" I learned.
Old 01-10-2012, 10:30 PM
DirtyDA9's Avatar
Or an unequal lenght header. I've totally been thinking about having one fabbed up, I love the sound of subbies, and everyone will look like "wtf?" thinking it's messed up or ej205 swapped lol
Old 01-10-2012, 10:31 PM
DirtyDA9's Avatar
Why not just subaru lol
Old 01-13-2012, 09:11 AM
seth01tuner's Avatar
Had a bad valve, it was running on 3 cylinders, sounded like a subaru and felt a great loss in power, mostly at low speed and getting off the line
Old 02-13-2012, 08:27 AM
chrisdavis6's Avatar
exactly what my gsr sounded like when i busted the belt.
Replaced it, started it up, sounded like an sti!
rebuilding head now, what a bitch getting old valve guides out!
Vtec Type R
06-02-2005 07:57 PM
n1mr0d
05-27-2005 10:03 AM
hybridhatch18
18
05-06-2003 10:18 PM
pelotudo
05-03-2002 08:26 PM
Quick Reply: What are the symptoms of bent valves?
