Help to All the Techs PLEAZ!
ok I was in fourth gear trying to slow down so i used the brake a little and then down shifted, but i down shifted into the wrong gear. after i did that my car woudln't work wright. every time i gave it gas, it tried to die, and when the car is running the timing belt is going hella slow. I was wondering if it is bent valves or if i skipped some teeth in the timing. Pleaz help!
Re: Help to All the Techs PLEAZ! (hybridhatch18)
odds are you bent your valves. my friend it the same thing but his car wouldn't even start. good luck take the head off and look
dAng!
Re: Help to All the Techs PLEAZ! (turbogixxer)
mis-shifts aren't your friend. Seeing as how your car still somewhat runs, it's obviously not nearly as bad as my screw up. (Click link in my sig if you don't know what i'm talking about)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">Do a compression test and it will tell if you bent a valve(s) or not.</TD></TR></TABLE>
actually if he bent valves on each cylinder that will give the same results as a skipped tooth on a timing belt.
check the Tbelt for TDC before you do anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridhatch18 »</TD></TR><TR><TD CLASS="quote">oh yeah itz a b18c1 and i went from 4th to 2nd</TD></TR></TABLE>
How the heck did you do that and miss 3rd altogether? 5th to 2nd or 4th to 1st I can see, but 4th to 2nd?
Re: Help to All the Techs PLEAZ! (Outrun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outrun »</TD></TR><TR><TD CLASS="quote">
How the heck did you do that and miss 3rd altogether? 5th to 2nd or 4th to 1st I can see, but 4th to 2nd?</TD></TR></TABLE>
where did he mention the word "accidentally?" probably an error in judgement.
Re: (makaveli284)
make sure the timing belt didnt slip first,then have a compression check done to it.You dont want to remove your head unless you really need to.
bnuk013
07-19-2006 08:36 AM
