P0135 and P0141
Old 05-23-2010, 09:47 AM
96civic turbo's Avatar
Icon2 P0135 and P0141
I recently purchased a 1996 Honda Civic EX Turbo for my son. The CEL is on and when I hooked up a cold reader, I get P0135 and P0141. Is it possible both O2 sensors are bad? The car has been setting for almost 3 years.
Old 05-23-2010, 11:59 AM
Former User's Avatar
Default Re: P0135 and P0141
First clear codes from the ECU to see whether the CEL codes repeat. Also check whether 7.5A dash fuse 15 is blown.
Old 05-23-2010, 12:01 PM
Pothole987's Avatar
Have you tried taking the sensors out and cleaning them?
Old 05-23-2010, 01:24 PM
Originally Posted by RonJ@HT
First clear codes from the ECU to see whether either CEL codes repeat. Also check whether 7.5A dash fuse 15 is blown.
Thanks RonJ, That did it. Fuse was blown.
Old 05-23-2010, 02:08 PM
Old 05-23-2010, 04:03 PM
Drove it around the block and no more O2 codes thrown. When I got on it, it threw a P0108 code. Any ideas?
Old 05-23-2010, 06:23 PM
Check the MAP sensor and its connector.
Old 05-23-2010, 06:36 PM
Will do.
Old 05-23-2010, 06:56 PM
xero_xero's Avatar
o2 sensors are a wearable item, and they need to be replaced every time you do your spark plugs. ESPECIALLY since your car is turbo, it will have bigger injectors and will consume more fuel. this will wear your o2 sensors more.
Old 05-24-2010, 02:13 AM
How do I troubleshoot a P0108 code?
Old 05-24-2010, 03:38 AM
xero_xero's Avatar
http://www.wonderhowto.com/how-to-te...ircuit-251789/
now, as for testing. you will probe the wires to the map sensor while it is running and plugged in. you will look for 1.8v(at signal wire) and less than 1ohm resistance (on ground) at idle. Near full throttle should read 4.9v(signal wire) at near full throttle.
Deadeyediaz
11-17-2012 11:27 AM
darmstro
09-21-2012 10:42 PM
nitewolf
08-25-2009 02:55 AM
rebuiltSI
07-24-2007 09:07 PM
Qwikrex
07-28-2002 03:31 PM
Quick Reply: P0135 and P0141
