CEL codes after installing O2 sensor
Old 07-24-2007, 07:54 PM
rebuiltSI's Avatar
Default CEL codes after installing O2 sensor
This is on a 99 Si: So I tried to replace my Secondary o2 sensor because of a Cat efficiency code (P0420). I used a universal Denso 4-wire sensor. I believe I wired everything correctly, so I plugged it back in and immediately the CEL came back on. I got the CEL read and it said P0141 (malfunction exists in the heater circuit for oxygen sensor 2 in bank 1). So I took it apart and reconnected the wires, crimped them, and used shrink wrap. I plugged it back in and immediately the CEL came back on. I got the CEL read and it came up with 4 codes!!! This is the list of codes:
P0500 (malfunction exists in the electrical circuit for the vehicle speed sensor)
Note- my odometer is not working now
P1298 (Electrical Load Detector Circuit Input High)
Replaced a burnt out fuse, #15 on the fuse box under the dash
P0135 (malfunction exists in the heater circuit for oxygen sensor 1 in bank 1)
Can anyone help me? Also, after I replaced the fuse #15 it blew out when I turned the car on again.
Old 07-24-2007, 08:01 PM
Global Moderator
tech8's Avatar
Default Re: CEL codes after installing O2 sensor (rebuiltSI)
Your O2 wires are probably shorting against something, and causing the other trouble codes, in addition to the blown #15 fuse.
Old 07-24-2007, 08:09 PM
rebuiltSI's Avatar
Default Re: CEL codes after installing O2 sensor (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">Your O2 wires are probably shorting against something, and causing the other trouble codes, in addition to the blown #15 fuse. </TD></TR></TABLE>
You made me think of something. When I spliced the wires together I used the metal connectors the you use in between the seperate wires to crimp them together. Well I think those metal pieces are touching cause they are shrink wrapped together. Hope thats it. Im going to go take it apart right now.
Old 07-24-2007, 08:14 PM
truevietluv636's Avatar
maybe you have to reset the ecu. not sure though.
Old 07-24-2007, 08:17 PM
Global Moderator
tech8's Avatar
Almost guaranteed that a short in the O2 wires are causing the other codes and blown #15 fuse.
Old 07-24-2007, 08:31 PM
Syndacate's Avatar
Default Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">Almost guaranteed that a short in the O2 wires are causing the other codes and blown #15 fuse.</TD></TR></TABLE>
Yeah, either that or he wired it wrong.
If you're 100% sure it's wired right, go under your dashboard, check the fuse in the 2nd row down, 5th row from the left (fuse #15), if it's blown it's shorting out someplace - you're speedometer also won't work and you might throw a code 20 for an electronic surge.
It sounds as though the wires as touching on the secondary O2, like you messed up the wiring or something. If it was grounding out to the chassis like tech8 said it'd pop that fuse and you'd throw a code 20 (electronic load) and your vehicle speed sensor wouldn't work (you wouldn't have a speedometer) and you'd be throwing an both O2 sensor heater lights.
Oh yeah, and your alternator won't charge your battery...it's pretty noticeable stuff.
I'm like 99.9999% sure you messed up the wiring when you hooked up the universal O2 - universal O2's SUCK for this reason right here.
Either they're touching, or they're not wrapped right, or you mixed up the O2 sensor heater wires, or something to that effect...check the wiring...then check the wiring...then check the wiring...then after you did that, reset the ECU, and check the wiring again - it's messed up, I'm almost willing to bet money that's where the issue is.
If it was a short like tech8 said it'd pop that fuse...again...that'd be from an exposed wire when you hooked it up...
Old 07-24-2007, 08:37 PM
Global Moderator
tech8's Avatar
Default Re: (Syndacate)
The short could be either his O2 wire grounding out against the chassis, or that the O2 wires are touching each other (e.g., (+) signal touching (-) signal, etc.).
Old 07-24-2007, 08:51 PM
rebuiltSI's Avatar
Default Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">The short could be either his O2 wire grounding out against the chassis, or that the O2 wires are touching each other (e.g., (+) signal touching (-) signal, etc.).</TD></TR></TABLE>
Bingo.. the O2 wires were crimped together using the metal connectors in the Universal o2 Sensor kit. The connectors where touching each other and causing it to short/blow the #15 fuse. I fixed the problem by wrapping each connector in electrical tape. Im a legitimate noob mechanic, but I never give up. Thanks guys for the help/recommendations.
Old 07-24-2007, 08:53 PM
Global Moderator
tech8's Avatar
Default Re: (rebuiltSI)
Glad you got it fixed. for DIY.
Old 07-24-2007, 09:07 PM
rebuiltSI's Avatar
Default Re: (tech8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 &raquo;</TD></TR><TR><TD CLASS="quote">Glad you got it fixed. for DIY.</TD></TR></TABLE>
I patted myself on the back.. a small DIY fix still feels good.
alpinegroove
30
10-13-2013 12:55 PM
DC2_Legend
04-16-2009 08:25 PM
llred_devil2001ll
06-04-2007 12:48 PM
SpoolinEK
05-21-2004 02:42 PM
LsPower
12-03-2002 08:56 AM
Quick Reply: CEL codes after installing O2 sensor
