DIY: Diagnose Check Engine Lights 4th gen Prelude
Old 02-08-2009, 07:19 AM
preluderemis's Avatar
Default DIY: Diagnose Check Engine Lights 4th gen Prelude
So I decided to do a write up on this since I get this question a lot and it’s not in the FAQ
Tools needed:
Paper clip or wire
Step 1: Locate the 2P connector behind the console driver’s side (near the gas pedal). It’s the blue one shown here.
Step 2: Take a paper clip or wire and form it into a U to use as your jumper.
Step 3: Insert the jumper in the 2P
Connector
Step 4: Turn the ignition to ON without starting the car.
The Check engine light should start to blink revealing your code. Codes 1-9 are indicated by short blinks. Codes 10-43 are revealed with short and long blinks. Long blinks indicated the first digit and short blinks the second digit. For exemple: Two long blinks and three short blinks would indicate code 23 (i.e. Knock Sensor, one I have personally seen many times lol). Multiple codes will be shown one after the other in order from 1 to 43. I personally have had 6 at the same time. After you have read the code(s) remember to remove the jumper.
Step 5: Reset the ECU by removing the clock/radio (10A) fuse or removing the negative cable from the battery.
Heres a list of the codes/helms manual reference:
ECU
Page: 11-31
OXYGEN SENSOR
Page: 11-36
3-5
MANIFOLD ABSOLUTE PRESSURE (MAP SENSOR)
Page: 11-44
CRANK ANGLE (CRANK SENSOR)
Page: 11-50
COOLANT TEMPERATURE (TW SENSOR)
Page: 11-52
THROTTLE ANGLE
Page: 11-54
TDC POSITION (TDC SENSOR)
Page: 11-50
No. 1 CYLINDER POSITION (CYL SENSOR)
Page: 11-50
10
INTAKE AIR TEMPERATURE (TA SENSOR)
Page: 11-56
12
EXHAUST GAS RECIRCULATION SYSTEM (EGR)
Page: 11-135
13
ATMOSPHERIC PRESSURE (PA SENSOR)
Page: 11-58
14
ELECTRONIC AIR CONTROL (EACV)
Page: 11-76
15
IGNITION OUTPUT SIGNAL
Page: 11-60
16
FUEL INJECTOR
Page: 11-96
17
VEHICLE SPEED SENSOR
Page: 11-62
20
ELECTRIC LOAD DETECTOR (ELD)
Page: 11-64
23
KNOCK SENSOR
Page: 11-68
30
A/T Fl SIGNAL A
Page: 11-70
31
A/T Fl SIGNAL B
Page: 11-70
41
OXYGEN SENSOR HEATER
Page: 11-38
43
FUEL SUPPLY SYSTEM
Page: 11-42
Remiss
Old 07-15-2009, 05:46 PM
Remiss's Avatar
Default Re: DIY: Diagnose Check Engine Lights 4th gen Prelude
Code 36 on the jdm P13 ecu is traction control witch only came in the jdm prelude obviously
discoverd that mine is throwing this today haha
Old 05-22-2011, 11:11 AM
bsvatora's Avatar
If the CEL does not blink at all and just stays on does that indicate a 0 fault code indicating ecu?
Old 05-22-2011, 11:16 AM
Hawkze_2.3's Avatar
If the MIL is on but not flashing (when jumped), there are MANY steps to take in the service manual before you need to replace the ECU....like 2-3 pages worth.
Old 04-08-2013, 03:14 AM
free00100's Avatar
Tools needed:
Paper clip or wire
Connector
ECU
Page: 11-31
OXYGEN SENSOR
Page: 11-36
3-5
Page: 11-44
Page: 11-50
Page: 11-52
THROTTLE ANGLE
Page: 11-54
Page: 11-50
Page: 11-50
10
Page: 11-56
12
Page: 11-135
13
Page: 11-58
14
Page: 11-76
15
Page: 11-60
16
FUEL INJECTOR
Page: 11-96
17
Page: 11-62
20
Page: 11-64
23
KNOCK SENSOR
Page: 11-68
30
A/T Fl SIGNAL A
Page: 11-70
31
A/T Fl SIGNAL B
Page: 11-70
41
Page: 11-38
43
FUEL SUPPLY SYSTEM
Page: 11-42
Remiss
Old 04-08-2013, 03:16 AM
free00100's Avatar
This is great!!! Thanks guys!!!
Guess I better go steal a clip from my wife and go checking.
Old 02-18-2014, 03:05 PM
preludeNApower's Avatar
Cut the connector and wire in a switch.
Now you can check codes very quickly
Old 03-21-2014, 11:06 AM
bamaland601's Avatar
kind of confused a little fellas, i've got 3 connectors, 2 are 2-pin(yellow&blue) and 1 is 3-pin (blue/grey)
when i jump the 2-pin blue the abs light flashes 4 slow 1 fast
when i jump the yellow 2-pin cel just stays on solid, while others all go off
Old 04-04-2014, 10:29 PM
Akuma888's Avatar
subscribing......
Old 09-30-2014, 06:32 PM
robertmorodan's Avatar
Well if it's not to late the 2 pin blue connector is the right one. Did you find out the abs code?
Old 11-17-2014, 06:11 PM
Franzwazwaz92's Avatar
Tools needed:
Paper clip or wire
Connector
ECU
Page: 11-31
OXYGEN SENSOR
Page: 11-36
3-5
Page: 11-44
Page: 11-50
Page: 11-52
THROTTLE ANGLE
Page: 11-54
Page: 11-50
Page: 11-50
10
Page: 11-56
12
Page: 11-135
13
Page: 11-58
14
Page: 11-76
15
Page: 11-60
16
FUEL INJECTOR
Page: 11-96
17
Page: 11-62
20
Page: 11-64
23
KNOCK SENSOR
Page: 11-68
30
A/T Fl SIGNAL A
Page: 11-70
31
A/T Fl SIGNAL B
Page: 11-70
41
Page: 11-38
43
FUEL SUPPLY SYSTEM
Page: 11-42
Remiss
What if my CEL doesn't come on when I just turn the key to the on spot only comes on when I start it ?
jdowen2
11-13-2012 08:31 PM
I-4
06-05-2007 03:29 AM
mdjplay
06-10-2004 05:54 PM
NoLipRacen
12-09-2003 09:27 AM
Drew313
12-10-2001 08:04 AM
Quick Reply: DIY: Diagnose Check Engine Lights 4th gen Prelude
