Where is the egr valve located?
Old 01-06-2009, 08:08 PM
jose310's Avatar
Default Where is the egr valve located?
can i clean it? I already cleaned the egr ports and fuel injectors, where is the valve located? and how can i clean it?
Old 01-06-2009, 08:35 PM
redline870's Avatar
Default Re: Where is the egr valve located?
it is located on top of the intake manifold
Old 01-06-2009, 08:48 PM
VTECn83's Avatar
Mine's is a 96EX but that should be close... Hope it helps.
Old 01-07-2009, 08:34 AM
jose310's Avatar
Is there a way to clean it?
Old 01-07-2009, 08:43 AM
P_Adams's Avatar
Just the passages at it's base, it's not ment to be taken apart.
I've used:
Wire Brush
Ice Pick
Scrapper
The passages in the intake manifold are more problamatic
Old 01-07-2009, 08:54 AM
H-T Order of Merit
TouringAccord's Avatar
I've also used carb cleaner in addition to a brush/scraper.
did it to the egr valve on my girls Jimmy 1.5yrs ago when it generated a code, hasn't been a problem since :knocks on wood:
Old 01-07-2009, 04:24 PM
GDD Member
slomofo's Avatar
I remove the valve, apply power to it to see if the pintle is moving up and down. If the pintle moves as it should, then grab a coat hanger and work it through the EGR ports on the manifold. Afterwards, I'll start the car and let it run for about 10 seconds to blow the ports clear, then reinstall EGR Valve.
Old 01-07-2009, 06:33 PM
HONDAPARTSMANMIKE's Avatar
do you have a check engine light on for an egr code p0401 or p1491? if it a p0401 its a flow code and needs that egr ports cleaned. if its a p1491 its a lift code usually needs a valve
Old 01-08-2009, 09:35 AM
jose310's Avatar
No i do not have a check engine light, just thought i would clean it.
BlkCivicFromTeamMNR.com
Acura TL, RL & ZDX
21
04-11-2009 07:21 PM
361 accord
03-21-2007 04:34 PM
XiOus271
02-06-2006 01:34 PM
riceball777
02-16-2004 11:53 PM
CaNaBiS
09-21-2002 09:18 AM
Quick Reply: Where is the egr valve located?
