I have a B16 block, ls motor, b16 head with type r internals, what should I do?
Old 06-01-2008, 07:05 PM
crxrider07's Avatar
Default I have a B16 block, ls motor, b16 head with type r internals, what should I do?
A few months ago i didnt have **** but my 91 hatch. Now i have a b16 motor with type r cams, valve springs and pretty much everything in the type r head. I also have a complete ls motor and a b20 block. I am looking for ideas and suggestions on what to go with. I am thinking of doing a b16 head on the b20 block. Please give a detailed opinion, and or seggestions. Thanx
Old 06-01-2008, 08:02 PM
Civic89stdB16's Avatar
Default Re: I have a B16 block, ls motor, b16 head with type r internals, what should I do? (crxrider07)
do the b16 head on the b20 block and just put jdm itr pistons in it and build the head. best all motor set up ever. if boost stick with the b16 and a 57 trim and arp head studs and push 12psi plus everyday.
Old 06-01-2008, 08:18 PM
beana's Avatar
if you have all the stuff from the type r head get a local machinist to port b16 head to typr r specs or do it better and go a lil bit more w/ the port job
then rebuild the head do a b20/vtec and slap the engine in w/ an ls tranny (lsd)
and go have some fun
Old 06-01-2008, 08:22 PM
nihad's Avatar
give it to me
Old 06-01-2008, 08:30 PM
CRex_22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beana &raquo;</TD></TR><TR><TD CLASS="quote">if you have all the stuff from the type r head get a local machinist to port b16 head to typr r specs or do it better and go a lil bit more w/ the port job
and go have some fun </TD></TR></TABLE>
naw go with b16 tranny shorter ratio
Old 06-01-2008, 08:52 PM
Crazy Honda Guy
Deetz's Avatar
Default Re: I have a B16 block, ls motor, b16 head with type r internals, what should I do? (Civic89stdB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic89stdB16 &raquo;</TD></TR><TR><TD CLASS="quote">do the b16 head on the b20 block and just put jdm itr pistons in it and build the head. best all motor set up ever. </TD></TR></TABLE>
WTF are you talking about?
A B20 block uses 84mm pistons, B16A/B, B18A/B , B18C engines all use 81 mm pistons
Don't spread missinformation
Old 06-01-2008, 09:05 PM
CRex_22's Avatar
Default Re: I have a B16 block, ls motor, b16 head with type r internals, what should I do? (Deetz)
jus do ls vtec then you can do itr
Old 06-02-2008, 09:24 AM
my bad. i ment ls vtec not b20 vtec.
Old 06-02-2008, 09:34 AM
meandino's Avatar
Default Re: (CRex_22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRex_22 &raquo;</TD></TR><TR><TD CLASS="quote">naw go with b16 tranny shorter ratio </TD></TR></TABLE>
X2 you will love it.
Old 06-02-2008, 12:35 PM
mra4886's Avatar
Default Re: (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">give it to me </TD></TR></TABLE>
yeah give me the head. or trade me the b16 head with all itr stuff in it for my completely built ls head. pm me iof interested. will give all details. not trying to make it a fs/ft thread or anything. lol
Old 06-02-2008, 05:22 PM
crxrider07's Avatar
Default Re: (mra4886)
email me at gsxrrider05@hotmail.com with the details about the head and trade. peace.
Old 06-03-2008, 06:58 PM
4GE4YA's Avatar
Default Re: (crxrider07)
Rs machine 84mm itr pistons with rings 300.00 bux!!! Then put that B16 head on that B20 bottom end. I would probably use a gsr main girdle, windage tray oil pan as well just to tie everything together.
Old 06-04-2008, 02:48 PM
Littlemotor's Avatar
Default Re: (4GE4YA)
Wouldnt he have to mill the regular b16 block to fit the GSR girdle?
B20inDCinLBC
09-18-2006 05:34 PM
eric22p
09-06-2006 09:38 PM
I LUV MY NINJA
08-27-2006 09:43 PM
Bongnak
09-10-2003 04:06 AM
Blaze45
12-29-2002 03:34 PM
Quick Reply: I have a B16 block, ls motor, b16 head with type r internals, what should I do?
