What direction does the crankshaft pulley bolt turn to loosen ? (d15b2)
Old 04-27-2008, 09:17 PM
demomano's Avatar
Default What direction does the crankshaft pulley bolt turn to loosen ? (d15b2)
Thank you.
Old 04-27-2008, 09:56 PM
Neebs's Avatar
Default Re: What direction does the crankshaft pulley bolt turn to loosen ? (demomano)
Should be right hand threaded. Counter-clock wise.
Old 04-27-2008, 10:04 PM
zero708970's Avatar
easiest way to take the pulley off (for me at least) is to take off the starter and get something caught in the flywheel and have someone else undo the bolt. word of caution though you could mess up one of the teeth oh, and that thing is on TIGHT! I got it off with a 5 foot pipe as a breaker bar and it still took us a while.
Old 04-27-2008, 10:58 PM
demomano's Avatar
Default Re: What direction does the crankshaft pulley bolt turn to loosen ? (zero708970)
Thanks....
tried to block the engine with gear and brakes on but clutch seems to slip when turning off with a breaker bar
going to try with pneumo tool...
Old 04-27-2008, 11:05 PM
demomano's Avatar
also heard that there is special tool used to block engine that fits into hexagonal socket of the pulley and it has a hole to put a socket on pulley bolt...
nate_o
26
04-23-2024 09:28 PM
sde780
09-03-2013 10:43 AM
luti
28
01-09-2005 01:05 PM
LowFlyin'
08-24-2003 07:21 AM
youngkow
11-22-2002 01:21 AM
Quick Reply: What direction does the crankshaft pulley bolt turn to loosen ? (d15b2)
