garrett tb03 good for low boost in B18CRX?
Old 01-26-2008, 06:33 AM
I CRX I's Avatar
Default garrett tb03 good for low boost in B18CRX?
just as the title says, im just looking for a quick daily driver, nothing really crazy. will this t3 be pointless is such a high revving motor? btw it has a .52 compressor side and .48 exhaust.
Old 01-26-2008, 07:50 PM
I CRX I's Avatar
i was also thinking about adding a 50 shot the equation. any input on this setup?
Old 01-26-2008, 09:58 PM
Maxcapacity's Avatar
Default Re: garrett tb03 good for low boost in B18CRX? (I CRX I)
That is a nice turbo to put on there.. you should have barely any lag.
Old 01-27-2008, 06:34 AM
I CRX I's Avatar
awesome, has anybody ever had any experience with this turbo?
Old 01-27-2008, 07:29 AM
AWDstylez's Avatar
You said "high reving," is this a GSR or an LS?
Old 01-27-2008, 08:41 AM
I CRX I's Avatar
Default Re: (AWDstylez)
its a JDM gsr
Old 01-29-2008, 05:08 AM
I CRX I's Avatar
somebody has to have had experience with this turbo?? its been out since like 1988
Old 01-30-2008, 03:45 AM
I CRX I's Avatar
ok so from what ive read, this little snail in off a 2.4 liter dohc 16valve chrysler motor that was good for 224hp @ 11psi (<correct me if im wrong on this.). im looking to add maybe 6-7 psi on a stock gsr, what numbers should i be expecting? heres a picture of it.
Old 01-30-2008, 05:59 AM
Semnos's Avatar
Default Re: (I CRX I)
It has probably a stage 1 turbine wheel and the small A/R .48 turbine. That will make your torque/power drop very quickly at higher rpm's.
When Vtec kick's in the turbo will choke the motor.
Old 01-30-2008, 06:03 AM
93supercoupe's Avatar
Default Re: (Semnos)
Seems way to small for a GSR, get something bigger and u shuld be way happier.
Old 01-30-2008, 08:18 AM
TIGboy's Avatar
Default Re: (93supercoupe)
get a bigger turbo..that thing is way to small for a gsr, it would be pointless.
GreenGSR
08-15-2009 08:47 PM
401tuner
10-03-2007 05:17 AM
S2KILLA
05-05-2006 01:41 PM
swappedcx
02-03-2006 04:32 PM
Hoosier Daddy
03-28-2004 10:36 PM
Quick Reply: garrett tb03 good for low boost in B18CRX?
