Noisy Valve train
Old 12-29-2007, 05:37 PM
eg6madness's Avatar
Default Noisy Valve train
I installed Buddy club Spec 4 cams, Buddy Club P1 valve springs (dual springs) and cam gears. Since then when i drive the head sound super noisy, there is a annoying rattle that sounds like something is loose.
A friend told me to recheck my Valve lash, another told me that it is the inner valve springs.
Anyone else installed similar and had tones of noise?
Old 12-30-2007, 03:53 AM
Syner-G-Racing LLC's Avatar
Default Re: Noisy Valve train (eg6madness)
check your lost motion assemblies...is it local to a certain area or does the hole head make noises? cause high lift cams and stiff valve springs are alot noiser than stock.
Old 12-30-2007, 05:16 PM
eg6madness's Avatar
Default Re: Noisy Valve train (Syner-G-Racing LLC)
It seems like the entire head.... it sounds like a train on tracks.....
Is that normal..... it takes some getting used to but it bites
Old 12-30-2007, 11:10 PM
wed3k's Avatar
i know for a fact that my buddies crower cams have a tighter valve lash clearance as opposed to stock.
.006-.008 as opposed to .009-.012
Old 12-31-2007, 01:16 AM
Default Re: (wed3k)
as long as the valve spring you got accomodate the lift on the cams to avoid coil bind your good. it sounds like its just noisy. you could post up a video or sound clip and we could help more
b20hatchek
13
03-20-2015 11:26 PM
State.of.Prime
10-17-2010 01:43 PM
daidilus
25
08-18-2006 08:21 AM
Home Wrecker
08-18-2006 05:50 AM
scUba-stEve
01-14-2005 03:55 PM
Quick Reply: Noisy Valve train
