does your car run with a blown head gasket?
Old 09-15-2007, 05:09 PM
jdmstockeg6's Avatar
Default does your car run with a blown head gasket?
does your car still run with a blown head gasket?
jdmstockeg6 is offline
Old 09-15-2007, 05:12 PM
pythoner's Avatar
it can...just not that good
pythoner is offline
Old 09-15-2007, 05:14 PM
Default Re: (pythoner)
oh. because my friend iis doing a mini me swap for me. and he just called and said i have a blown head gasket? how do you repair/fix this problem?
and what kind of "not running good" do you mean? thanks
Old 09-15-2007, 05:24 PM
H-T Poker champion
Hatchy-Ownzjo0's Avatar
Default Re: (jdmstockeg6)
Step one: Remove head
Step two: Remove old head gasket
Step three: Replace old head gasket with new head gasket
Step four: Put head back on and torque all bolts to spec
You don't want to run with a blown head gasket. You will eventually destroy the engine.
It's not hard to replace, especially with the engine out of the car.
Hatchy-Ownzjo0 is offline
Old 09-15-2007, 05:26 PM
Default Re: (Hatchy-Ownzjo0)
how much does a new gasket cost?
Old 09-15-2007, 05:29 PM
garrettsc60-1's Avatar
might as well do a timing belt while you in there, and the cam and crank seals.
garrettsc60-1 is offline
Old 09-15-2007, 05:31 PM
Default Re: (garrettsc60-1)
yeah hes replacing all that. hes doing the mini me swap. thanks
Old 09-15-2007, 05:32 PM
hmtcrxsir's Avatar
depends on where you go. I would prefer OEM Honda/Acura Headgasket because it was made with quality and those usually cost $100-$150 depending on where you go. I found one on ebay for $80 which is from OEM Honda. Felpro also makes one that i used in the past and it worked great. It never gave me a problem and you can find it at Kragen, PepBoys, Autozone. And the price is about $40 at Autozone. For a peace of mind, I would say OEM
hmtcrxsir is offline
Old 09-15-2007, 05:35 PM
Default Re: (hmtcrxsir)
how hard is it to replace a head gasket?
Old 09-15-2007, 06:16 PM
Ex-Eg-Driver's Avatar
Its a tedious job. Could take a whole day if you arent really mechanically inclined like myself.
Ex-Eg-Driver is offline
Old 09-15-2007, 06:26 PM
biggishjay's Avatar
well if he is doing that swap he would replace the headgaskit anyway. i would think
biggishjay is offline
Old 09-15-2007, 06:30 PM
Daughter not possible
Rude Awakening's Avatar
Default Re: (biggishjay)
It will sound like a WRX after any idling.
Cool beans.
Rude Awakening is offline
Old 09-15-2007, 06:59 PM
95ProjectEJ1's Avatar
Default Re:
http://www.slhondaparts.com
http://www.hondapartsdeals.com
I just replaced mine and Im pretty sure it didnt cost anywhere near 100-150. I picked up a head gasket, valve cover gasket and timing gear all shipped for about 190.
If you are on the west coast go with slhondaparts and if you are on the east go with hondapartsdeals... why do you ask? Shipping times
95ProjectEJ1 is offline
Old 09-16-2007, 12:03 PM
hmtcrxsir's Avatar
Default Re: Re: (95ProjectEJ1)
thats how much i paid for mines. you get good deals on ebay. just make sure you get OEM when ordering from ebay
Old 09-16-2007, 12:36 PM
EJ1_Sleeper's Avatar
Default Re: Re: (hmtcrxsir)
mine ran for awhile, but would spew coolant out of the overflow, cause exhaust was getting in to the cooling part of the HG. Just replace it.
EJ1_Sleeper is offline
Old 09-16-2007, 01:15 PM
numberone's Avatar
Default Re: (JayKayNidas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayKayNidas &raquo;</TD></TR><TR><TD CLASS="quote">Its a tedious job. Could take a whole day if you arent really mechanically inclined like myself.</TD></TR></TABLE> Not hard, it takes an 1 1/2 hours. If your mechanically inclined like myself.
numberone is offline
Old 09-16-2007, 02:02 PM
jonezen1's Avatar
Default Re: (numberone)
go to streetimports.com.they have decent prices for heag gaskets and stuff. I biult my b16 with the gasket set they have and it pretty good. you can even specify how thick( layers ) you want the gasket to be.
jonezen1 is offline
Old 02-09-2015, 10:01 AM
bsozak's Avatar
Default Re: does your car run with a blown head gasket?
Just give a sealer a try before you go and get it replaced, it could save you a ton of money. Use something like Blue Devil or Bar's. Here's a link - Head Gasket Sealer | Head Gasket Sealant | BlueDevil
bsozak is offline
Old 02-09-2015, 11:30 AM
I never narc'd on nobody!
NotARaCist's Avatar
You just bumped an 8 year old, dead thread, with absolutely **** poor advice. I hope your future posts are much better than this one - you're off to a rocky start.
NotARaCist is offline
Cho0se
02-24-2020 02:59 PM
TravisCadello
17
04-10-2009 11:29 PM
dropped like its hott
09-15-2007 01:11 PM
da_33
01-11-2007 11:12 AM
king tuck
10-07-2004 04:15 PM
Quick Reply: does your car run with a blown head gasket?
