HELP!!! getting out rusted caliper bolts
Old 11-07-2006, 04:19 PM
msinsky14's Avatar
Default HELP!!! getting out rusted caliper bolts
my rear brakes or woen down all the way and I tried to remove the lower bolt holing the caliper on but I broke an extension trying to remove it. how can i get out rusted bolts??? need help ASAP, by the way, I used wd40 and tried pb blaster but the bolt was soooo freaking stobborn. Is there a way to maybe scrape the rust off somewhat?
Modified by msinsky14 at 5:31 PM 11/7/2006
Old 11-07-2006, 04:32 PM
saikou's Avatar
Default Re: HELP!!! getting out rusted caliper bolts (msinsky14)
PB Blaster, patience, some muscle and a breaker bar.
Or if you have access to an impact gun, that would work quite easily.
EDIT:
Ah, you edited your post to include the PB Blaster & WD-40 before I posted. Patience man, just let that PB Blaster soak in; maybe even over-night. Possibly even a cheater pipe attached to a breaker bar for even more leverage. Or like I said, an impact gun.
EDIT AGAIN:
Should have read your post a little slower. You're having trouble on the REAR caliper bolts. Alright, I would definitely recommend heating the bolt until it glows dark red, wait until it cools down just enough (practice) and it will come out with minimal effort
Old 11-07-2006, 04:43 PM
Charliegrs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikou &raquo;</TD></TR><TR><TD CLASS="quote">PB Blaster, patience, some muscle and a breaker bar.
EDIT:
Ah, you edited your post to include the PB Blaster & WD-40 before I posted. Patience man, just let that PB Blaster soak in; maybe even over-night. Possibly even a cheater pipe attached to a breaker bar for even more leverage. Or like I said, an impact gun.</TD></TR></TABLE>
thats all great advice except for the impact gun part. if the bolts are rusted on theres a really good chance you will break the head of the bolt off if you use an impact gun.then you have a REALLY big problem. ive done it before quite a few times myself.
soak the crap out of the bolt with pb blaster, let it sit a while, use a long breaker bar and a pipe and it should come off. if it doesnt, hit the weights lol
Old 11-07-2006, 07:19 PM
SKDRCR's Avatar
Default Re: HELP!!! getting out rusted caliper bolts (Charliegrs)
Try putting the closed end of a wrench on it
then hammer the **** out of the wrench with 1
clean shot. I use that technique a lot but
it doesnt work for everybody
Old 11-07-2006, 08:40 PM
TheWalrus's Avatar
i wouldnt use a closed end wrench, most of them are 12 point so its easier to strip the bolt head. use a 6 point socket with a long ratchet, hold the socket on there good and hammer or kick the end of the ratchet. also try tapping the bolthead lightly and respraying with pb
Old 11-07-2006, 09:09 PM
soundbomber's Avatar
Default Re: (weenie)
ratcheting wrench
Old 11-07-2006, 09:28 PM
lude98SH's Avatar
Default Re: (soundbomber)
Yea on a bolt that tight using a 12 pointer is asking for problems. I would just soak it in deep creep or pb blaster. And then get a 6 point socket and breaker bar and try it. If that doesnt work use a cheater bar on the breaker bar just make sure u dont come off the bolt and then ur on straight and are pushing straight down.
Old 11-18-2006, 08:50 AM
msinsky14's Avatar
its been 2 weeks and I've tried everyday and the sockets just rip right off the bolts. I think I'm gonna have to heat them up, oh yea, and earlier today, my ABS failed when I was playing chicken with an SUV which I prolly shouldnt have been doing. but it feels so much better with no ABS system. then some old guy in a mercedes tried to chase me down. whoops, I'm not gonna do that again.
Old 11-18-2006, 09:10 AM
AndyD's Avatar
I invested in the Craftsman socket set that is designed for stripped bolts. I love this socket set.
I recommend getting a set.
Old 11-18-2006, 04:13 PM
msinsky14's Avatar
Default Re: HELP!!! getting out rusted caliper bolts (AndyD)
am i able to remove the bolt that gets in the way while trying to remove the lower inner bolt? it comes down at an angle to the ground( soeey I dont know what it is). and does the stripped bolt set slip off rusted bolts? b/c I seem to have a grip and then suddenly, it slips right off it and it even feels like the bolt became to big...
Old 11-18-2006, 06:05 PM
SteveoBA8's Avatar
My rear driver lower caliper bolt wouldnt budge either, remove the caliper from the mounting bracket and use a torch, mine finally broke loose.
Edit/\oops i meant remove the caliper bracket with the caliper still bolted to the bracket( remove the hose).
Modified by SteveoBA8 at 7:18 PM 11/18/2006
Old 11-18-2006, 06:08 PM
msinsky14's Avatar
Default Re: HELP!!! getting out rusted caliper bolts (SteveoBA8)
I cant get the lower bolt off that allows me to remove the caliper from the bracket either. that ones rusted on pretty badly as well
Old 11-18-2006, 08:33 PM
msinsky14's Avatar
I thought u were supposed to pull the caliper from the bracket first anyways? am i right?
Old 11-20-2006, 07:53 AM
lude98SH's Avatar
It would make it easier im sure
HotCheetos
10
12-11-2010 09:07 PM
MI4$DC5
19
04-02-2005 09:10 AM
igo4bmx
13
01-17-2004 11:13 PM
syndicate43
11-25-2002 05:49 PM
b18bvudoo
08-15-2001 10:01 PM
Quick Reply: HELP!!! getting out rusted caliper bolts
