What causes the 2nd to 3rd gear grind? why does it grind?
Old 05-06-2002, 08:00 PM
GQ 05YellowEVO8's Avatar
Default What causes the 2nd to 3rd gear grind? why does it grind?
Why on earth does the 2nd to 3rd gear usually grind when drag racing?
Why is it difficult to get it into gear?
Old 05-06-2002, 08:02 PM
Dr Pooface's Avatar
Default Re: What causes the 2nd to 3rd gear grind? why does it grind? (VTEC-MAN95GSR)
You cant shift, or your syncros are gone.
Old 05-06-2002, 08:05 PM
Beard
Rguy's Avatar
Bad shifting? hehe, j/k. The only times ive had that problem is my own mistake, ie letting the clutch out a millimeter too early.
Old 05-06-2002, 08:23 PM
JDMITR222's Avatar
Default Re: What causes the 2nd to 3rd gear grind? why does it grind? (Rguy)
Yeah i would say youre just trying to shoot the shifter straight across too fast and you're not having the clutch all the way in at that time.Hope this helps
Old 05-06-2002, 08:44 PM
Default Re: What causes the 2nd to 3rd gear grind? why does it grind? (JDMITR222)
Hummmm....I may have done that on numerous occasions
As of now I'm thinking of ways to rebuild my tranny....
Old 05-07-2002, 03:49 AM
hooptie157's Avatar
man the syncos in these cars SUCK. Are they any after market ones that I could use the replaces these pieces of !@#
[Modified by hooptie157, 4:49 AM 5/7/2002]
Old 05-07-2002, 04:31 AM
sutats's Avatar
Yeah, I've had this problem before and am having this problem again now. Honda did a good job by fixing the 3rd gear synchromesh which was covered under warranty. That was a few months ago now. It's grinding again now, I'm bringing it in to Honda this Friday. I'm not sure if they should've replaced the gear together with the synchro the last time, instead of just the synchro itself. Cheers!
shorty10388
09-17-2005 12:49 PM
Bond
01-31-2005 07:14 PM
crzyfool24
11
09-26-2004 09:48 PM
TypeRTexan
04-13-2004 11:30 AM
Jeager521
08-11-2003 09:25 AM
Quick Reply: What causes the 2nd to 3rd gear grind? why does it grind?
