misfire around 2500 rpm
Old 05-20-2006, 10:25 AM
hndriver's Avatar
Default misfire around 2500 rpm
96 ex 280 k
cel blinks around 2500-2750
code is misefire cly #2
cleaned egr
changed plug wires
dis car
can't figure this out
Old 05-20-2006, 04:04 PM
notoriousB's Avatar
Default Re: misfire around 2500 rpm (hndriver)
how did the plug from # 2 look? any oil on it?
how does the car idle? seem normal?
could be as simple as a bad injector, could be as bad as a piston down on compression.
to rule out the injector you can swap #1 and #2 - see if the code follows the injector
to rule out a bad cylinder do a compression test
Old 05-20-2006, 05:16 PM
hndriver's Avatar
Default Re: misfire around 2500 rpm (notoriousB)
plugs lean all the same
replaced and changed wires
did the swtich around
may be random missfire and just codeing po302?
car idles a little rough
did compression test all around 160
all injectors clicking
only seems to do this in the 2500-2750 rpm range
that should be when the egr opens yes?
Old 05-20-2006, 09:07 PM
DraKonX's Avatar
I'm guessing EGR ports and maybe even the valve.
Remove the fuel rail and everything attached to it and set it aside, probably don't have to fully remove it even, just unbolt all the bolts. Then remove the cover below it. Clean out your EGR ports. Also check your EGR valve itself, it may need cleaning or replacing. Be sure you have or can easily get a replacement gasket for the valve in case you can't reuse the one already on there.
Had this problem on mine, though mine seemed to do it when running at a steady 45 - 55 mph, and on rare occasions higher then that. It idled fine though, thats the only thing that makes me wonder if what yours is doing is because of something else.
Other possibility could be dirty injector(s). They'd probably still mechanically check out ok, but not be spraying correctly.
I'd check the EGR valve and ports though. If EGR ports are blocked it will cause those that are not blocked to take the extra load and misfire.
Edit: Noticed you said you cleaned the EGR, I missed that bit, though I still am not sure if you just did the valve, or the ports, or both.
Old 05-21-2006, 05:01 AM
hndriver's Avatar
Default Re: misfire around 2500 rpm (DraKonX)
I just cleaned the valve
am thinking it has to have
something to do with that
I'll have another look at it
Old 05-21-2006, 12:22 PM
hndriver's Avatar
I reviewed the egr posts
will clean the other part
of the system
Old 07-29-2014, 03:57 AM
HondaNathan's Avatar
I have the same problem on my 1997 ex, vtec. Did you figure if it was the EGR valve? My code is p0301 - misfire cylinder 1.
Thanks.
Ephosay
11-16-2013 04:45 AM
stevedrum4578
06-15-2013 08:08 AM
Winlight
22
02-13-2011 08:42 PM
SHystrdyGSRtdy
09-07-2005 08:51 PM
AntonioH
08-01-2005 09:52 AM
Quick Reply: misfire around 2500 rpm
